On Mon, 09 Mar 2015 23:41:34 -0700, Movses wrote:
On Monday, March 9, 2015 at 2:55:07 PM UTC-7, wrote: You must not be using the USB stick at the end of each flight. I think the key is that you must shut off the FLARM, then insert the USB memory stick, then turn the FLARM back on and it downloads the just flown flight log. I flew with my PowerFLarm for the first time last summer, did this action, and every log was transfered to the USB memory stick and I posted them that evening on OLC. A standard FLARM typically holds up to the last ten flight logs in its internal memory. If its an LX RedBox FLARM, when you put the SD card in and turn it on, ALL the logs that aren't already recorded on the card are written to it. The red LED flashes while its doing this. Its quite slow, taking noticeably more time to write several logs than just one. Since all FLARMs run the same software, they should all do the same. I'd be surprised if the PowerFLARM doesn't do it too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
What display do you use and is its firmware the latest?
Post your flarmcfg.txt file here - it may explain the problem (or email it to me). You haven't answered what firmware for your CORE you're running. You haven't answered what size USB drive you're using, nor confirmed it's USB 2.0, nor what it is formatted as. Have you tried downloading with someone else's USB drive, which is confirmed to work? |
Flarm to MIO 400 | [email protected] | Soaring | 1 | January 23rd 15 06:05 PM |
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files | Ian Strachan | Soaring | 0 | July 20th 14 07:28 PM |
FLARM IGC files: erasable? | [email protected][_2_] | Soaring | 5 | May 20th 13 07:46 PM |
FLARM for SAR | FLARM | Soaring | 57 | November 21st 12 07:21 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
