Thanks everybody for replies;
this confirms that at least, I have the correct understanding of the process. I'll recheck everything when I get to the ship next time and follow up. Movses On Tuesday, March 10, 2015 at 10:47:04 AM UTC-7, Paul Remde wrote: Hi Movses, I suspect that the USB flash drive is not compatible for some reason. Perhaps it is formatted using FAT instead of FAT32 or vice versa. Or perhaps it is too large in regard to capacity. What is the capacity of the USB flash drive? It is my understanding that the PowerFLARM Core and Core Pure units will always log a flight that is accepted by the OLC. The IGC enable and a calibration make them valid for badges and most records. Best Regards, Paul Remde Cumulus Soaring, Inc. ____________________________________ "Movses" wrote in message ... On Monday, March 9, 2015 at 2:55:07 PM UTC-7, wrote: You must not be using the USB stick at the end of each flight. I think the key is that you must shut off the FLARM, then insert the USB memory stick, then turn the FLARM back on and it downloads the just flown flight log. I flew with my PowerFLarm for the first time last summer, did this action, and every log was transfered to the USB memory stick and I posted them that evening on OLC. The answers to this is pretty much all previous questions is yes... To my best knowledge: - configuration file is uploaded - usb stick in, then power on, monitor led, power off when done. - not sure on firmware, will give this another try when I get to the airport next time. Sigh.. I'm a software engineer, I'm usually the one who's good with this stuff ![]() |
![]() USB sticks should: · be formatted with FAT (FAT16 or FAT32) file system (NTFS or exFAT will not work) · have capacity = 32GB · Be of USB 2.0 type (not USB 3.0; USB 3.0 connectors are typically blue on the inside). Richard www.craggyaero.com |
Flarm to MIO 400 | [email protected] | Soaring | 1 | January 23rd 15 06:05 PM |
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files | Ian Strachan | Soaring | 0 | July 20th 14 07:28 PM |
FLARM IGC files: erasable? | [email protected][_2_] | Soaring | 5 | May 20th 13 07:46 PM |
FLARM for SAR | FLARM | Soaring | 57 | November 21st 12 07:21 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
