Oudie to Cambridge
Old March 11th 15, 02:25 PM posted to rec.aviation.soaring
HGXC[_3_]
Default Oudie to Cambridge
On Tuesday, March 10, 2015 at 10:57:06 PM UTC-4, Paul Remde wrote:
Hi,
I wonder, is there any chance that you have the pin order backwards. Pin 1
is on the right when connecting to the back of the male connector. It is on
the left when looking at the pins. Make sure you use a magnifying glass and
get the light angle right so you can read the raised pin number markings.
Best Regards,
Paul Remde
"HGXC" wrote in message
On Friday, March 6, 2015 at 5:17:11 PM UTC-5, vontresc wrote:
On Friday, March 6, 2015 at 4:06:35 PM UTC-6, Paul Remde wrote:
Hi,
I show the connections for the RJ45 to DB-9m adapter for use with a
GPS-NAV
and Oudie he
http://www.cumulus-soaring.com/seeyo...pter-RJ45-DB9m
Make sure you set the Oudie to comm port 4 and 4800 baud.
The SeeYou Mobile software can receive GPS and pressure altitude data
from
the GPS-NAV. I don't think it can receive vario or airspeed data sent
through from an L-NAV.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
On Friday, March 6, 2015 at 12:56:42 PM UTC-5, vontresc wrote:
HGXC wrote:
Anyone using an Oudie connected to a Cambridge GPS model 20? I have
a
few questions.
Dennis
Yes mine is hooked up to a model 20 and s-nav.
What do you need to know?
Pete
Perhaps we can private email...
But in general I am setting up the DB9 serial connect so the Oudie can
talk
to the Cambridge
I would like to see a photo of the pin set up on the male serial that
plugs
into the Cambridge. Also if you are only using 3 pins (Sending
Receiving
and Ground) what do you do with the rest of the wires? Does the plug
only
show 3 pins?
Also how can i tell of the oudie is taking GPS from the cambridge? My
glider
is in storage but i can plug my cambridge in to power it up and I can
take
the three pins and insert them into the Cambridge and plug the mini usb
into
the Oudie. When i do that it is saying it lost GPS signal and is going
to
internal GPS so i am confused.
Thanks ...obviously I don't do electronics well.
Dennis
Paul is spot on. I still have the original Oudie cable that had a DB9
connector instead of the RJ45. That original cable will plug rught into
the DB9 on the back of the Model 20. Thena all you need to do is to
connect the power connectors to the ships power and you are done.
If you have the newer version with the RJ45 then follow Paul's
instructions to wire it up.
To test it you can go to the serial terminal mode under settings/hardware.
Should be 4800baud 8N1
Peter
Peter all...its a bit frustrating as i still get a warning that I lost my
primary GPS signal and going to back up. When i go to hardware i get the
reading 4800 baud N 8 1. Its charging right from my 12 volt. I have tripled
checked my red black and orange pins. Now i haven't clicked them in the
converter yet i am just sticking the pins individually into the 2,3,and5
sockets.
Any other set up stuff i could be missing?
Dennis
"Make sure you use a magnifying glass and
get the light angle right so you can read the raised pin number markings."
BINGO! I didn't take into consideration that I must be blind - I was off in the pin settings everything looks to be working now.
Thanks!
Dennis
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 06:57 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
