Wheel brake cable?
Old March 13th 15, 04:04 AM posted to rec.aviation.soaring
Movses
Default Wheel brake cable?
The brake cable on my ship needs to be replaced - stretched, adjustment barrel is already at the end of the range, etc.
The diameter of the cable is 2mm, and it seems like they don't use 2mm cables on bicycles anymore. 1.6mm brake cables are readily available, but I'm not sure if they're adequate.
Where do I get 2mm cables?
-Movses
Old March 13th 15, 04:19 AM posted to rec.aviation.soaring
Bill T
US , Aircraft Spruce, but I only see it listed in fractions for diameter, not by mm.
BillT
Old March 13th 15, 03:24 PM posted to rec.aviation.soaring
Peter von Tresckow
BillT
Try a motorcycle shop. They may still use 2mm cable. Otherwise find an OLD
bike shop. They may have some old stock in the back still.
Peter
Old March 13th 15, 09:59 PM posted to rec.aviation.soaring
Dan Marotta
5/64 is a tiny bit smaller than 2 mm.
On 3/13/2015 9:24 AM, Peter von Tresckow wrote:
BillT
Peter
Dan Marotta
Old March 13th 15, 10:09 PM posted to rec.aviation.soaring
When I had the brake cable snap on my LAK-17A during a contest, I was able to get a new cable made up at a local motorcycle shop while I waited. I don't know if it was 2mm, but it was larger than a bicycle brake cable, and matched what was on the glider (including end fittings).
Marc
Old March 13th 15, 10:41 PM posted to rec.aviation.soaring
Craig Funston
-Movses
Motorcycle clutch cable. I got mine from a local motorcycle race shop. The big dealerships don't deal much in older stuff. In your case, you're near "Bent Bike" north of Seattle. Or there's always Amazon.
http://smile.amazon.com/Venhill-U01-...productDetails
Old March 15th 15, 10:56 AM posted to rec.aviation.soaring
Pierre Vav
When time came to change I used high quality bike cable with modern housing.
That helped a little the poor braking of my glider.
The cable is thinner and friction reduced.
Maybe it wil brake sooner, I'm pretty sure it won't: I am not that stronger in my glider than on the bike.
Old March 15th 15, 12:53 PM posted to rec.aviation.soaring
Per Carlin
I also replaced the old worn out cable with a 1.5mm this winter. Guess that I have to keep an extra eye on it,the old 2mm help up for at least 10 years.
PW-5 Brake Cable Replacement [email protected] Soaring 1 July 31st 14 07:41 PM
Duo Discus Wheel Brake Karl Striedieck[_2_] Soaring 1 January 24th 12 10:49 PM
SZD-55 Wheel Brake David Pye[_2_] Soaring 4 September 19th 07 03:10 AM
SZD-55 Wheel Brake David Pye[_2_] Soaring 0 September 18th 07 06:01 PM
Pilatus B-4 Wheel Brake Cable thermalrider Soaring 2 January 28th 06 11:12 PM
