Ads-b and sailplanes
Old March 25th 15, 10:15 PM posted to rec.aviation.soaring
Andrew Ainslie
Default Ads-b and sailplanes
Has anyone been following the latest moves from the FAA on ads-b and experimental aircraft? A recent article in flying suggested that they are going to relax the requirements for experimental planes so they need a GPS source that is equivalent in performance to TSO'd units.
If this is true, it might relax the requirements for those with Trig TT22 transponders so that they can use cheaper GPS sources like the GRT GPS-EXT-RAIM unit that they sell for just under $500.
I've decided that it's cheap enough to give a try, so I just ordered one and will be playing with it over the next few months. It certainly beats forking out $3000 on the TSO'd unit sold by Trig.
If anyone has opinions, experience or also intends playing with this I'd love to hear. I fly out of Harris hill which is right by a big iron airfield and it'd be nice to see them on a screen before bumping into them. I also like the idea of a couple of us flying with ads-b out so that people around us get to see the in portion. S emus like even a relatively small percentage of us on the new standard could help safety given the idiot decision by the FAA to restrict access to the "in" data to a hockey puck around each plane with "out".
Old March 26th 15, 02:01 AM posted to rec.aviation.soaring
Darryl Ramm
Maybe next time try searching r.a.s. before asking a question. You would have found this has been covered in depth here recently...
Old March 26th 15, 02:37 AM posted to rec.aviation.soaring
Andrew Ainslie
Thanks for the help. Sentences like "TSO-C199 devices are a reduced feature Mode-S (and optionally 1090ES Out) based traffic saftey beacon system hopefully suitable for gliders, balloons and maybe UAVs inter-operating with GA and above aircraft equipped with PCAS/TCAD/TCAS/ADS-B In" are deeply helpful to those of us working our way into this topic. I'm deeply indebted.
Old March 26th 15, 03:01 AM posted to rec.aviation.soaring
Andrew Ainslie
Well, I have indeed discovered that you have strong opinions on the topic, and are able to command an impressive array of acronyms that it'd take me hours to google. Care to offer a newbie more than a dismissive flame?
Old March 26th 15, 03:03 AM posted to rec.aviation.soaring
Bill T
Darryl, I've been looking and for most standard certificated aircraft, not experimental, it takes STC to install ADS-B equipment. A couple of STCs I have found do not list the Piper Pawnee, PA-25. Any Pawnee I have seen is registered under Restricted category. Any ideas?
BillT
Old March 26th 15, 08:35 AM posted to rec.aviation.soaring
Darryl Ramm
BillT
Bill, it does not directly take an exact STC to install an ADS-B Out. But the FAA does wants an STC to act as the basis for a field approval. What I believe they mostly care about is the GPS, ADS-B Out device and required peripherals (e.g. control heads etc.) and wiring interconnect are known to work together/have been though a proper STC process. (and to see the horror involved there look at AC 20-165A).
The first FAA clarification that a field approval was acceptable was this http://download.aopa.org/aircraft/121105faa-ads-b.pdf
Bottom line is if you had to do this now for some reason, then I'd have a read of this stuff, but basically get out you check book and find a good avionics facility and talk with them and/or the manufacturer and/or and the local FSDO if needed (a good shop should really do all that for you), about what is possible/how exactly to get field approval. If they have not done a field approval based ADS-B Out installs of similar equipment I would *not* want to be the first customer lined up with my aircraft to have them do this.
A list of approved/STC'ed pairings of ADS-B Out and GPS sources is included in this newsletter https://www.faa.gov/nextgen/ga/media...stallation.pdf (may be slightly out of date).
But it is just way too early today, I would wait until manufactures are (hopefully) offering affordable transponder/1090ES Out with built in GPS (which AFAIK will still need to be fully TSO-ed for a restricted category aircraft, but the integrated install still will make things easier). And let the manufacturer of that help your avionics shop with how to get that install field approved.
Old March 26th 15, 10:46 AM posted to rec.aviation.soaring
Darryl Ramm
ADS-B Out GPS sources no longer need to be explicitly TSO'ed, they do need to "meet requirements of" the relevant TSO. That does not mean that any old random GPS will do. In fact no consumer GPS or any GPS with a NMEA output would be acceptable. The "RAIM" claims by GRT Avionics do not mean that GPS receiver "meet the performance requirements" of the relevant IFR GPS TSO.... it could not as is (since it only appears to communicate via NMEA), I expect they are doing some proprietary RAIM signalling to their own EFIS boxes. Who knows. Unless vendors are quoting exact TSO or RTCA specs things like saying the GPS has "WAAS" or "RAIM" become fairly useless marketing terms..
And that does not mean that an install in a certified aircraft (including glider) will not require a TSO'ed GPS. That minor wording change was mostly a win for the experimental powered aircraft folks, many of those owners will need to meet the 2020 ADS-B Out carriage mandate, and can now do so with non-TSO'ed GPS sources that "meet the performance requirements of...".
It has always been the case that in an experiential aircraft can install a non-TSO (and non-meets performance of...) GPS source for ADS-B Out as long as all the basic things are done right and the aircraft correctly transmits the appropriate SIL parameters to advertise it is using a non-complaint GPS source. However that will *not* meet the 2020 carriage mandate, and allow that aircraft to fly in airspace requiring ADS-B Out (again which glider are largely exempt from). And that "non-compliant" ADS-B Out carriage may or may not (it appears that it often does) result in the FAA ADS-B ground infrastructure today providing ADS-R and TIS-B service for that aircraft (in the hockey pucks around the aircraft you referred to), or certified airborne ADS-B receivers seeing that aircraft. And that situation may change (i.e. worsen) in future.
Your goal of wanting to have some aircraft flying around with ADS-B out so it would activate the FAA ground station based ADS-R and TIS-B services for nearby aircraft might seem attractive but is likely not useful at best, or a dangerous idea at worst. It's not useful if you expect the other aircraft to be gliders equipped with PowerFLARM receivers, as PowerFLARM does not receive ADS-R or TIS-B transmissions. Even if you had gliders equipped with suitable ADS-B receivers you still have the problems that ADS-R and TIS-B service volumes are are pretty shallow (e.g. +/- 3.500' for TIS-B) and you get the very bad traffic warning situation where if your aircraft is not equipped with ADS-B Out then you see traffic on your ADS-B In traffic display only near other ADS-B Out equipped aircraft, and once the traffic flys away from those other ADS-B out equipped aircraft, possibly towards you, they can drop off the traffic display. There is *no* way a pilot can look at any ADS-B traffic display and try to reverse engineer in their mind what is going on, what traffic is being painted for what client aircraft etc. You could help encourage very dangerous situations where pilots start thinking their ADS-B receiver can see/warn about traffic, and then all of a sudden the traffic actually a threat to them becomes invisible. If your glider is airborne and a client for ADS-R and TIS-B and you descent below service coverage (which might be pattern altitude or higher)then all of a sudden and with no warning to other pilots all TIS-B and ADS-R traffic show on all displays on all aircraft in that area could just disappear. If you want to use ADS-R and TIS-B safely you *need* ADS-B Out in your aircraft. That is just how the broken system was designed to work. The saving grace is hopefully most aircraft will equip with 1090ES Out, in which case any PowerFLARM unit will "see" them, independent of any ADS-B ground infrastructure/line of sight, radar coverage or having the glider ADS-B Out equipped.
So again, we get back to the old simple advice that if you fly gliders near busy airspace and are worried about running into fast jets and airliners etc. then by far the most effective technology related thing you can do is install a transponder... and it is fantastic to see you have. The 1090ES In part of a PowerFLARM can help point out some airliner/fast jet/high-end GA traffic to you, but especially with fast traffic you want them seeing/avoiding you with TCAS, and that takes a transponder. If you are worried about GA aircraft then the combination of a transponder and the PCAS part of PowerFLARM can be pretty useful.
All this stuff has been hashed out in other threads here before. If you don't understand much of this stuff or can't spend time Googling acronyms and working out what things means then you probably should not be worried about trying to be at the bleeding edge of this technology. It can be expensive to play with today, rapidly changing from a product viewpoint, and is just a technical and regulatory mess. Far too much crap for the average glider pilot to want to deal with. It is great that you already have a transponder installed in your glider, but now you spent $600 on a GPS receiver that will do nothing more for you techncially than any decent consumer/WAAS receiver, or just connecting to the NMEA out from a PowerFLARM (which I also hope you already have). Sure you can install this in your experimental category glider (you always could, even before the changed CFR14 wording you are referring to) with the appropriate SIL settings. It won't get you any closer to meeting 2020 carriage requirements (which was not your goal). And it *may* (apparently *should* at least today) trigger FAA TIS-B and ADS-R ground based services for your aircraft if you are in range of those ground stations (and you also have to correctly configure the CC/Capability Code bits in the Trig for it to advertise the aircraft has an ADS-B receiver and on what link layer).... but if your ADS-B receiver is a PowerFLARM it can't receive ADS-R or TIS-B to begin with, but it will keep seeing the 1090ES Out equipped traffic it is already seeing....
Old March 26th 15, 01:19 PM posted to rec.aviation.soaring
Bob Pasker
from AC 20-165A:
(c) The ADS-B equipment can only allow an anonymous 24-bit address selection if
the Mode 3/A code is set to 1200
I wonder if they will add 1202 as well (see http://www.faa.gov/documentLibrary/m.../N7110.577.pdf)
Old March 26th 15, 05:16 PM posted to rec.aviation.soaring
Darryl Ramm
No they will not. This was done to largely placate AOPA and others who lobbied the FAA. Those organizations really should have been worrying more about fundamental issues with how broken the whole dual link approach is.... Instead of stuff like this or prioritizing keeping aging Mode C transponders in use. And the anonymous mode only applies to UAT Out. Any 1090ES capable transponder is already transmitting the aircraft's ICAO address and that cannot be disabled (try it and you will likely get a visit from the FAA). And if glider owners ever want to install any of this mess it is 1090ES Out not UAT out they should install -- for compatibility with PowerFLARM, and since you need a transponder anyhow for TCAS compatibility.
Old March 26th 15, 05:24 PM posted to rec.aviation.soaring
Darryl Ramm
Oops somehow the opening few words of my first paragraph that should have started with "To meet the 2020 carriage mandate ..." Got deleted,
Sailplanes currently in production?? [email protected] Soaring 0 November 10th 11 01:02 AM
LS-1 sailplanes in the USA Burt Compton - Marfa Soaring 2 November 2nd 10 12:08 AM
Please ID 3 sailplanes Every time Soaring 4 August 20th 08 09:34 PM
Cheap sailplanes tango4 Soaring 100 December 21st 04 08:21 PM
50+:1 15m sailplanes Paul T Soaring 92 January 19th 04 01:59 AM
