Karl, To save money and time you can match them with replacements from:
Bansbach Easylift of North America, Inc. 50 West Drive Melbourne, FL 32904 Tel (321) 253-1999 Fax (321) 253-5546 www.easylift.com You need to know the force, length open and closed. Also tell them the type of end connectors (eyelet, etc.). -PC |
I saw this Arcus in person. It does have a prop on the front.
On Wednesday, April 1, 2015 at 2:33:12 PM UTC-6, son_of_flubber wrote:
This approach is cleaner http://www.youtube.com/watch?v=zpluCYve9qw&t=5m32s OK, with full recognition that it's April 1st, an electric ducted fan has some advantages for self-launch in that ~60 knots is right in the middle of the "sweet spot". It could beat any open prop's thrust/Watt ratio at that speed. |
On Wednesday, April 1, 2015 at 5:47:39 PM UTC-4, Bill D wrote:
On Wednesday, April 1, 2015 at 2:33:12 PM UTC-6, son_of_flubber wrote: This approach is cleaner http://www.youtube.com/watch?v=zpluCYve9qw&t=5m32s OK, with full recognition that it's April 1st, an electric ducted fan has some advantages for self-launch in that ~60 knots is right in the middle of the "sweet spot". It could beat any open prop's thrust/Watt ratio at that speed. I think the best use for this toy would be as a single-use emergency sustainer. It develops 5.5 kg maximum thrust, 12 lbs of thrust... say 10 lbs for hand waving ease. So an 800 lb gross weight glider with L/D 40:1 requires 20 lbs of thrust to sustain altitude. Add one of these 'toy' engines for 10 lbs of thrust would in turn give the glider an equivalent L/D of 80:1 while the turbo was running. Run it intermittently while flying between thermals. Turn it off and let it cool while you climb in the thermal. Add 2 turbos for redundancy. Run both and you have an intermittent use sustainer. It pushes on the airframe with a force of 10-20 pounds. Power from Duracells Alkaline batteries. Cheap. High energy density and a long shelf life. |
mmmm power is the typical EDF high perf setup of 12s 5000 Lipos. Full throttle time is ..not much. Overall 3 to 5min with throttle management. 30 sec max at full. Therein is the problem for full size. Full throttle for anything more than 30 seconds will kill those batts. I think this was a Shuebeler fan which is nice fan though.
Hybrid Engines?? | sisu1a | Soaring | 16 | March 15th 09 12:30 PM |
The Best Hybrid Car For You | n41beyha | Piloting | 0 | November 27th 07 04:52 PM |
bio-diesel hybrid future | John T | Home Built | 9 | September 2nd 05 01:22 PM |
bio-diesel hybrid future | John T | Piloting | 8 | September 2nd 05 01:22 PM |
bio-diesel hybrid future | Martin Hotze | Piloting | 0 | August 27th 05 01:42 PM |
