Wow! Ooops, take #3
Old April 3rd 15, 01:32 AM posted to rec.aviation.soaring
Bill T
Default Wow! Ooops, take #3
It will only be a matter of time before the U.S. FAA issues an AD based on the AESA AD that will impact gliders in the US.
US owners should heed the cautions and not operate the SOLO engine.
Interesting that the AD specifically identified the previous SOLO service bulletin as not acceptable.
BillT
Old April 3rd 15, 02:14 AM posted to rec.aviation.soaring
Looking at the Solo website http://aircraft.solo-online.com/index.php it looks like the c model is very different in that it shows a belt drive while the straight 2350 shows a direct drive. It appears that the AD is only for the C model.
DVM
Old April 3rd 15, 03:42 AM posted to rec.aviation.soaring
God doesn't like motors on sailplanes.......
Old April 3rd 15, 08:46 AM posted to rec.aviation.soaring
Tango Whisky
It affects ONLY 2350C engines with non-foldable propellor. That's DG1000T in the first place (which caused the AD) and probably J'S. S-H is not concerned (and I'll use it on my Ventus cM).
Old April 3rd 15, 01:52 PM posted to rec.aviation.soaring
John Galloway[_1_]
DG1000T
Also the turbo Antares - or at least the prototype according to this:
https://www.youtube.com/watch?v=-mxwvd-ps2A
Old April 3rd 15, 09:15 PM posted to rec.aviation.soaring
Jonathan St. Cloud
DG1000T
Try buying an Antares 23, they are not even being made.
Old April 3rd 15, 01:49 PM posted to rec.aviation.soaring
Dave Walsh
I think it says more about the technical competence of the
engine designers; maybe God doesn't like them either?
Old April 3rd 15, 02:42 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Well, crankshafts don't like to be loaded at their output location other than along the axis of rotation. Put a belt reduction drive on there, and you are applying load perpendicular to that. Interesting dynamics happen with a two cylinder in-line engine with this setup. It is not an easy system to design.
Steve Leonard
Old April 3rd 15, 02:48 PM posted to rec.aviation.soaring
Dave Nadler
Steve Leonard
The failure is the prop hub (receiving end of belt reduction),
not at the crankshaft. Last round was classic fatigue - nice
crystalline structure on broken part.
Old April 3rd 15, 03:44 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
Same sort of issue. Up and down loading on that shaft due to increasing and decreasing tension because of engine dynamics and the loading going in and out of phase with the prop being in low or high moment of inertia relative to the motion (prop horizontal, low moment of inertia relative to motion created by pushing up and down by the drive belt). Likely source of the fatigue failure. But, as stated before, these are complex systems with lots of interactions. Be interesting to know the crack propagation direction relative to the blades on the prop.
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops ... incident at Santa Fe A. Sinan Unur Piloting 18 November 10th 06 01:44 AM
Derby weekend ooops Jack Harkin Soaring 0 June 22nd 06 05:44 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
