Wow! Ooops, take #3
Old April 3rd 15, 03:44 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Wow! Ooops, take #3
On Friday, April 3, 2015 at 8:48:59 AM UTC-5, Dave Nadler wrote:
On Friday, April 3, 2015 at 9:42:40 AM UTC-4, Steve Leonard wrote:
Well, crankshafts don't like to be loaded at their output location
other than along the axis of rotation. Put a belt reduction drive
on there, and you are applying load perpendicular to that.
Interesting dynamics happen with a two cylinder in-line engine
with this setup. It is not an easy system to design.
Steve Leonard
The failure is the prop hub (receiving end of belt reduction),
not at the crankshaft. Last round was classic fatigue - nice
crystalline structure on broken part.
Same sort of issue. Up and down loading on that shaft due to increasing and decreasing tension because of engine dynamics and the loading going in and out of phase with the prop being in low or high moment of inertia relative to the motion (prop horizontal, low moment of inertia relative to motion created by pushing up and down by the drive belt). Likely source of the fatigue failure. But, as stated before, these are complex systems with lots of interactions. Be interesting to know the crack propagation direction relative to the blades on the prop.
Old April 3rd 15, 06:10 PM posted to rec.aviation.soaring
Dave Nadler
Steve Leonard
Same sort of issue.
Yep.
Crack propagation direction wasn't obvious on the broken part I saw.
Propagation *appeared* to have started at stress points from inadequate
flange radius and/or rough machining marks.
Not my area of expertise!
See ya, Dave
Old April 3rd 15, 07:13 PM posted to rec.aviation.soaring
Eric Munk
I have seen a picture of the fracture. Could be a brittle fracture, but
can't say for sure without having seen it live... I am sure Solo will be on
to it. Engine apparently was run well within operating limits, had very low
time and had the mandatory SB performed (new part failed).
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops ... incident at Santa Fe A. Sinan Unur Piloting 18 November 10th 06 01:44 AM
Derby weekend ooops Jack Harkin Soaring 0 June 22nd 06 05:44 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
