HPH 304eS at AERO 2015
Old April 16th 15, 05:59 PM posted to rec.aviation.soaring
kirk.stant
Default HPH 304eS at AERO 2015
I wonder if it would be possible to use a single blade prop (yes, they exist, look it up) and have it stored in a recess under the nose when stopped, to minimize drag.
That would be a bit more complicated (for the door to cover the prop) but would probably make the FES more acceptable to hard-core racers.
FESBPS, anyone?
Old April 16th 15, 07:48 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
FESBPS, anyone?
There are several dynamics issues with the single blade prop that would require a lot of effort to resolve if you are to be able to fold and stow the single blade (counterbalance weight, and where will it go?). Might be easier to stick with the two blades and stow them in recesses in the nose, similar to big wipers. Or, as you suggested, inside doors. for the hardcore racers.
Old April 16th 15, 08:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Hiller made a helicopter with a single blade, counter weight on the other side.
Old April 16th 15, 10:06 PM posted to rec.aviation.soaring
jfitch
FESBPS, anyone?
Plus, no ground clearance issues to take off, always keep the blade up!
