Bioenno Power LiFePO4 12V Glider Batteries
Old April 19th 15, 03:37 PM posted to rec.aviation.soaring
Dan Marotta
Default Bioenno Power LiFePO4 12V Glider Batteries
Not Tom, but I have two LiFePO4 batteries with two toggle switches wired
to a common DC bus. Switchover is simple: raise the second switch,
lower the first.
On 4/18/2015 11:22 PM, wrote:
Tom:
I am curious how you have two batteries wired in the DUO? Parallel, two switches to a common bus?
Inquiring minds want to know!
Thanks
Dan Marotta
Old April 20th 15, 02:51 AM posted to rec.aviation.soaring
[email protected][_1_]
Thanks, Dan. There seems to be a plethora of over-thinking on this subject, but I could be wrong......
Old April 20th 15, 12:48 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
A little searching on RS, Farnells, and similar outlets will find break-
before-make changeover switches. If the momentary voltage drop as you
throw the switch causes problems, put a decently sized capacitor
(1000-2000 microfarad) across the output lines of the switch with a small
resistor 10-15 ohms) in series with it. The resistor may be unnecessary:
its mainly there to limit to power surge to about 1A when the battery is
connected and, as the panel only draws around 400mA with everything on,
is too small to cause a significant voltage drop while the switch is open
circuit.
The season before last I discovered that, if I kicked the XLR plug
feeding power to my panel when I was getting in, the momentary power drop
would switch my radio and main vario off Putting a 2000 microfarad
capacitoy and 10 ohm resistor across the panel side of the plug has been
a permanent cure.
I've watched it with a voltmeter across the panel side: it takes about a
second for the voltage to drop to zero when the battery is disconnected,
so the momentary disconnection if I kick the plug isn't nearly long
enough to drain the capacitor.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 20th 15, 04:42 PM posted to rec.aviation.soaring
On Mon, 20 Apr 2015 11:48:46 +0000, Martin Gregorie wrote:
I see I left a badly edited mess, so here is another try:
Another way of solving the battery switching problem is to use a break-
before-make change-over switch. These are often rotary switches.
suitable switches for 12 volts at the sort of currents we require.
small resistor (10-15 ohms) in series with it. The resistor may be
unnecessary: its mainly there to limit to power surge to about 1A when
the battery is connected.
feeding power to my panel when I was getting into my cockpit, the
resulting momentary power glitch would switch my radio and main vario off,
which was annoying. Putting a 2000 microfarad capacitor and 10 ohm
resistor across the panel side of the plug has been a permanent cure.
My panel only draws around 400mA with everything on so, even with the
resistor in circuit, the capacitor is able to supply enough voltage and
current to keep the panel alive over the short period while the
connection in the plug is lost: with the capacitor charged to 12v the 10
ohm resistor limits current to 1200 mA. As this is three times more than
the panel requires, it won't affect the operation of any instruments
while the capacitor is powering them.
To check this I put a voltmeter across the panel side of the connector
and, with a stable 12v shown, disconnected the battery. It took about a
second for the voltage to drop to zero. In other words the momentary
disconnection if I kick the plug isn't nearly long enough to drain the
capacitor and cause anything to switch off.
org |
Old April 20th 15, 04:57 PM posted to rec.aviation.soaring
I have used a "break before make" toggle switch in everyone of my gliders and they have worked perfectly. Never had an instrument shut down or restart. Makes life very simple while flying.
Old April 21st 15, 02:25 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Don't you mean "make before break"? I use a rotary swithch with capacitors and a power resistor in parallel. Also works fine.
___________________
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
Experience with StarkPower LIFEPo4 Batteries? Papa3[_2_] Soaring 15 May 7th 13 07:17 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
Glider Batteries and Chargers Grider Pirate Soaring 29 September 1st 10 05:52 AM
