Towpilots ignoring turn signals
Old May 1st 15, 03:57 PM posted to rec.aviation.soaring
Justin Craig[_3_]
Default Towpilots ignoring turn signals
https://www.youtube.com/watch?v=RhKpp1eMAbA
At 14:36 01 May 2015, Dan Marotta wrote:
Jim,
Did you wave him off or drop the rope? Ropes and rings are expensive!
On 5/1/2015 7:08 AM, Jim David wrote:
As a tow pilot, I have no problem letting the glider steer me.
As a glider pilot, I have no problem giving the tow pilot directional
suggestions. However, If the tow pilot is unresponsive to my suggestions,
I
don't push the envelope much past the normal wake boxing position.
That would be stupid.
Once a glider pilot tried to steer me toward a bank of clouds at our
current altitude, and I refused. He was frustrated I guess, because he
yanked my tail in the same direction a second time, as if forgetting to
release the rope. The tow was an instructional flight and the instructor
was attempting to demonstrate steering. He could have easily gone the
other
way, which was clear of clouds. So, I terminated the tow.
See ya...
The practice isn't inherently dangerous, done correctly. Some pilots
don't.
Jim.
Dan Marotta
Old May 1st 15, 04:25 PM posted to rec.aviation.soaring
kirk.stant
It would be cool to have a Swift towed by an Extra 300, they could do counter-rotating synchronized rolls on tow...with colored smoke, that would look awesome!
Kirk
Old May 4th 15, 12:50 AM posted to rec.aviation.soaring
Jim David
On Friday, May 1, 2015 at 10:37:05 AM UTC-4, Dan Marotta wrote:
Jim,
Did you wave him off or drop the rope?* Ropes and rings are
expensive!
Dan Marotta
Hi Dan,
My situation was pretty violent. It was a botched attempt at steering. There were two very strong tugs to my left, one after another. After the second wallop, I was convinced that the glider pilot thought he had released and was executing his clearing turn (we were near the release altitude).
I personally know two tow pilots that have been the recipient of clearing turns after the glider pilot _thought_ they had released and both tow pilots ended up standing on the rudder peddles. One wound up in an inverted spin.
I didn't want to give the glider pilot a third try, so I released them.
The instructor was smart enough to return to the airport with the rope.
I've never been yanked that hard, even in wave turbulence.
Believe me, they deserved the rope.
Regards,
Old May 4th 15, 01:49 AM posted to rec.aviation.soaring
Dan Marotta
Understand. Thanks for telling your story.
I had a glider get so far out of position once (high and outside the
turn) that, as I was reaching for the release, he dived across my tail,
wrapping the rope around the wing of his borrowed HP-14. The wing was
cut, top and bottom, all the way to the spar. He didn't even realize
what he'd done until that evening he when he asked for help derigging.
I was invited to come over and have a look.
Dan
Jim,
expensive!
Dan Marotta
Hi Dan,
Regards,
Dan Marotta
Old May 4th 15, 03:57 AM posted to rec.aviation.soaring
Student pilot he can someone please explain why the SSA signals for the turn are the opposite of what is in the FAA Glider Flying Handbook?
That seems like it could cause some confusion. The SSA signals seem to make more sense, and seem accurate to what is discussed here.
https://www.faa.gov/regulations_poli...a/gfh_ch07.pdf Figure 7.2
vs
http://www.soaringsafety.org/briefings/signals.html
-Garrett
Old May 4th 15, 04:05 AM posted to rec.aviation.soaring
vs
-Garrett
This version of the Glider Flying Handbook is incorrect.
UH
Old May 4th 15, 01:20 PM posted to rec.aviation.soaring
PGS
vs
-Garrett
Garrett, The FAA publication is WRONG.
Old May 4th 15, 04:11 PM posted to rec.aviation.soaring
C-FFKQ (42)
On Monday, 4 May 2015 10:37:09 UTC-4, Dan Marotta wrote:
...Because the FAA version is (gasp) wrong!
Dan
Think about it... if the glider flies out to the far right, it drags the towplane's tail to the right, thus pointing the towplane nose to the left... causing a left turn.
Hence, the FAA version is wrong.
Tom Knauff has been (unsuccessfully) trying to get the FAA to correct the numerous errors in that book.
Old May 5th 15, 03:30 AM posted to rec.aviation.soaring
Frank Whiteley
Dan
Think about it... if the glider flies out to the far right, it drags the towplane's tail to the right, thus pointing the towplane nose to the left.... causing a left turn.
The SSA and SSAF tried unsuccessfully to review the draft. Note the foreword thanks to the SSA at ssa.com. When the FAA version was published, that domain was still for sale at a ridiculous price, and had been for nearly 20 years. Looks like the other SSA finally got their hands on it.
Frank Whiteley
illegal signals knocking out gps macpacheco Instrument Flight Rules 0 January 22nd 11 02:04 AM
Winch Signals Nyal Williams[_2_] Soaring 88 April 20th 09 01:00 PM
Why are people ignoring the ADS-B Out NPRM? Ron Lee[_2_] Piloting 30 December 20th 07 01:15 PM
Tow Signals Ramy Soaring 58 October 19th 06 04:46 AM
Ignoring the Challenger? robert arndt Military Aviation 0 July 1st 03 10:24 AM
