IOS App for Skylines?
Old May 4th 15, 07:53 PM posted to rec.aviation.soaring
jfitch
Default IOS App for Skylines?
On Monday, May 4, 2015 at 8:38:19 AM UTC-7, Karl Kunz wrote:
The problem with the iOS devices is there is not a good daylight readable option.
On Monday, May 4, 2015 at 7:34:51 AM UTC-7, Dan Marotta wrote:
Well, then, why doesn't someone who's a competent programmer and who
likes Apple products just do it?
On 5/4/2015 3:42 AM, Bruce Hoult wrote:
On Monday, May 4, 2015 at 8:29:37 AM UTC+3, Surge wrote:
The GPL License is incompatible with many application-distribution-systems, like the Mac App Store, and certain other software distribution platforms (on smartphones as well as PCs). The problem lies in the right "To make a copy for your neighbour", as this right is violated by the integrated DRM-Systems made to prevent copying of paid software.
That may be the FSF's line, but it is not correct.
Nothing restricts you from putting your app in the Mac App Store and also distributing it in other ways (e.g. from your own web site) without DRM. Many apps do this e.g. BBEdit
Nothing restricts you from making the source code of a Mac App Store app available, which also preserves the "free as in speech" demands of the GPL. Anyone is free to get a developer subscription and xCode and compile the source code themselves. (applies also to iOS app store).
Dan Marotta
Actually I find the iPhone 6+ to be more readable than an Oudie/Avier/V2 in any light at any angle. I own both.
Old May 5th 15, 03:36 AM posted to rec.aviation.soaring
Sean Fidler
Same here. iPhone 6 and the Galaxy Note 4 are far, far (the two smartphones that I use), better than the now ancient Oudie in literally every conceivable form of measure other than raw brightness. Thee difference in total brightness is very small now with the latest smartphones. SeeYou is so outdated that its almost comical. It truly pains me to use an Oudie when the far better devices are in the pocket of my glider (still illegal to use them in the USA although that might be evolving soon...).
Old May 5th 15, 06:26 AM posted to rec.aviation.soaring
jfitch
Only illegal to use them with the cell transmitter on, and then only for obsolete reasons. "could result in suspension of service and/or a fine" - does anyone know of a fine that has been paid? If you carry a cell phone in your glider you realize you have to have the regulations posted on or near each cell phone...
Old May 5th 15, 08:28 AM posted to rec.aviation.soaring
Bruce Hoult
Oh! It's a FCC regulation, not an FAA one?
In NZ it's always been common for pilots to use their mobile phones. Very often you can be shadowed from air traffic control transponders by mountains (or simply distance and lack of radio power) and ATC doesn't even blink when a pilot phones them in-flight with a position report or query.
Old May 5th 15, 03:50 PM posted to rec.aviation.soaring
jfitch
Yes, FCC, at the request of the network operators, from 20 years ago when there were technical problems with too many towers in range and speeds exceeding the handoff assumptions.
Old May 5th 15, 04:19 PM posted to rec.aviation.soaring
Dan Marotta
As a retired engineer I recall the old wisdom that "better is the enemy
of good enough".
My ancient Dell Streak 5 ($100) running XCSoar (free!) gives me the same
information that your systems do though it does not bring me a
cappuccino and massage my shoulders while I fly... Sure the new
products are great, calling what works comical is simply snobbish.
Dan Marotta
Old May 5th 15, 07:11 PM posted to rec.aviation.soaring
jfitch
enemy of good enough".
same information that your systems do though it does not bring me a
cappuccino and massage my shoulders while I fly...* Sure the new
Dan Marotta
"My ancient Dell Streak 5 ($100) running XCSoar (free!) gives me the same information that your systems do" Well, - in a word - No. There is no doubt that it costs a lot to approach perfect, but I could as easily say that I can get the same information from a pellet variometer and a sectional chart as you get on your Dell Streak. Yet the discerning person notices a difference.
Old May 5th 15, 08:11 PM posted to rec.aviation.soaring
Ok, so how about listing a few bullet points of the things that you can do on your iOS device (running what SW package?) that can't be done on Android running XCsoar? This isn't an attempt to be argumentative - I'd really just like to understand why one is or isn't better than (or equivalent to) the other.
Robert
Dan Marotta
Old May 5th 15, 09:59 PM posted to rec.aviation.soaring
jfitch
Robert
products are great, calling what works comical is simply snobbish..
Dan Marotta
Without being argumentative, give me a list of bullet points that you can do on XCSoar that can't be done with a printed chart and a slide rule.
None of these give you anything you could not have gotten before, they just do so with less pilot workload. The elegance of a superior UI is not easily distilled to bullet points. I have used both XCSoar and iGlide (iOS) for the last two years in about equal amounts. Anything you routinely do on XCSoar is more quickly accomplished (usually much more quickly) with less user attention on iGlide. In this regard SYM is a distant third. Actually standing second is Winpilot with a better UI than XCSoar or SYM even 15 years old - but it is no longer maintained so not in the running. If you put two pilots side by side and have them do some routine task on the PDA, while counting gliders flying by the canopy, you will see a big difference. An example might be adding a turnpoint between TP3 and TP4 in a task. How many click does that take you on XCSoar?
I do not want to dis XCSoar in particular, the price point is great, it does an OK job compared to others, and is feature rich if you can find them. It is not a pinnacle of UI advancement however, either due to the experience of the authors or (perhaps) the constraints of having to make it work on highly disparate hardware. I do dis SYM a bit, really no excuse for them - but of course SY itself is pretty much the same train wreck of UI, so it's inbred.
I will give you one bullet point for the iGlide/Air Vario combination that you cannot do on anything else though: instantaneous wind presented each second around your thermal circle. Which is surprisingly (maybe even alarmingly) useful.
Old May 5th 15, 11:14 PM posted to rec.aviation.soaring
Dan Marotta
Inserting a turnpoint into a task on XCSoar: IIRC, touch the turnpoint
on the map, press "Insert into task" from the pop up. That'll insert the
TP between my present location and the next TP. If it must be between
TP2 and TP3, I can simply wait until passing TP2 before touching the
desired TP.
As to daily use, I fly mainly tours out to 100 miles or so from the
airport rather than predefined tasks. Having said that, I rarely touch
my Streak as it always shows the information that I want to see. I
programmed these selections on the ground about 4 years ago and they
still suit my needs.
The fact that Winpilot is no longer maintained is of no consequence. If
it worked back then and wasn't "maintained", it'll still work just the
same way. Of course, it hasn't been "improved" but so what? People set
world records using that package as they will using what you're using today.
Robert
Dan Marotta
Dan Marotta
skylines down? Brad[_2_] Soaring 0 April 28th 15 05:01 AM
How are flights in SkyLines scored? kirk.stant Soaring 2 April 12th 14 08:43 AM
SkyLines Updates Tobias Bieniek Soaring 3 April 24th 13 07:33 AM
