iPhone 6 Plus and iGlide
Old May 4th 15, 09:41 PM posted to rec.aviation.soaring
jfitch
Default iPhone 6 Plus and iGlide
I wired in a usb charing port, so it stays charged. Best to start the day with the phone charged though, otherwise it will drain the instrument battery to charge the phone battery.
Old May 4th 15, 10:11 PM posted to rec.aviation.soaring
Mike Rinaldi
I have a portable charger I fly with. Very small and light. Will keep my iPhone charged all day. Bought it on Amazon.
Old May 5th 15, 03:26 AM posted to rec.aviation.soaring
Sean Fidler
Buy a Mophie perhaps? This is what I use for my iPhone when flying with iGlide. The Mophie is a $100 "battery case" that provides roughly 3500 mAh of additional battery capacity (120% additional). With a Mophie, there is no need for wires or a separate portable battery in the cockpit. The mophie case is only slightly larger than a normal case. The Mophie case setup will run an iPhone running iGlide all day (8 hours plus). Far longer if one does not leave the screen on constantly. Also, the Mophie charges from the same single USB wire at night. No need to charge two batteries separately (two wires and charging adapters). No more forgetting to charge the spare battery. Just a thought. www.mophie.com
Old May 17th 15, 07:02 PM posted to rec.aviation.soaring
I picked up an 8600mah PowerBurst from Costco for $30. It will fully charge my iPhone5 3 times and after flying for 5 hours the phone is still at 100%. It has to be connected by cord to the phone but that has been workable so far.
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
Butterfly iGlide App now available in the US Marc - Butterfly Avionics Soaring 25 June 2nd 14 08:10 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
