IOS App for Skylines?
Old May 5th 15, 09:59 PM posted to rec.aviation.soaring
jfitch
Default IOS App for Skylines?
On Tuesday, May 5, 2015 at 12:11:56 PM UTC-7, wrote:
Ok, so how about listing a few bullet points of the things that you can do on your iOS device (running what SW package?) that can't be done on Android running XCsoar? This isn't an attempt to be argumentative - I'd really just like to understand why one is or isn't better than (or equivalent to) the other.
Robert
On Tuesday, May 5, 2015 at 1:11:12 PM UTC-5, jfitch wrote:
On Tuesday, May 5, 2015 at 8:20:09 AM UTC-7, Dan Marotta wrote:
As a retired engineer I recall the old wisdom that "better is the
enemy of good enough".
My ancient Dell Streak 5 ($100) running XCSoar (free!) gives me the
same information that your systems do though it does not bring me a
cappuccino and massage my shoulders while I fly...* Sure the new
products are great, calling what works comical is simply snobbish..
On 5/4/2015 8:36 PM, Sean Fidler wrote:
Same here. iPhone 6 and the Galaxy Note 4 are far, far (the two smartphones that I use), better than the now ancient Oudie in literally every conceivable form of measure other than raw brightness. Thee difference in total brightness is very small now with the latest smartphones. SeeYou is so outdated that its almost comical. It truly pains me to use an Oudie when the far better devices are in the pocket of my glider (still illegal to use them in the USA although that might be evolving soon...).
Dan Marotta
"My ancient Dell Streak 5 ($100) running XCSoar (free!) gives me the same information that your systems do" Well, - in a word - No. There is no doubt that it costs a lot to approach perfect, but I could as easily say that I can get the same information from a pellet variometer and a sectional chart as you get on your Dell Streak. Yet the discerning person notices a difference.
Without being argumentative, give me a list of bullet points that you can do on XCSoar that can't be done with a printed chart and a slide rule.
None of these give you anything you could not have gotten before, they just do so with less pilot workload. The elegance of a superior UI is not easily distilled to bullet points. I have used both XCSoar and iGlide (iOS) for the last two years in about equal amounts. Anything you routinely do on XCSoar is more quickly accomplished (usually much more quickly) with less user attention on iGlide. In this regard SYM is a distant third. Actually standing second is Winpilot with a better UI than XCSoar or SYM even 15 years old - but it is no longer maintained so not in the running. If you put two pilots side by side and have them do some routine task on the PDA, while counting gliders flying by the canopy, you will see a big difference. An example might be adding a turnpoint between TP3 and TP4 in a task. How many click does that take you on XCSoar?
I do not want to dis XCSoar in particular, the price point is great, it does an OK job compared to others, and is feature rich if you can find them. It is not a pinnacle of UI advancement however, either due to the experience of the authors or (perhaps) the constraints of having to make it work on highly disparate hardware. I do dis SYM a bit, really no excuse for them - but of course SY itself is pretty much the same train wreck of UI, so it's inbred.
I will give you one bullet point for the iGlide/Air Vario combination that you cannot do on anything else though: instantaneous wind presented each second around your thermal circle. Which is surprisingly (maybe even alarmingly) useful.
Old May 5th 15, 11:14 PM posted to rec.aviation.soaring
Dan Marotta
Inserting a turnpoint into a task on XCSoar: IIRC, touch the turnpoint
on the map, press "Insert into task" from the pop up. That'll insert the
TP between my present location and the next TP. If it must be between
TP2 and TP3, I can simply wait until passing TP2 before touching the
desired TP.
As to daily use, I fly mainly tours out to 100 miles or so from the
airport rather than predefined tasks. Having said that, I rarely touch
my Streak as it always shows the information that I want to see. I
programmed these selections on the ground about 4 years ago and they
still suit my needs.
The fact that Winpilot is no longer maintained is of no consequence. If
it worked back then and wasn't "maintained", it'll still work just the
same way. Of course, it hasn't been "improved" but so what? People set
world records using that package as they will using what you're using today.
Robert
cappuccino and massage my shoulders while I fly... Sure the new
Dan Marotta
Dan Marotta
Old May 6th 15, 04:47 PM posted to rec.aviation.soaring
On Tuesday, May 5, 2015 at 5:14:30 PM UTC-5, Dan Marotta wrote:
Inserting a turnpoint into a task on XCSoar:* IIRC, touch the
turnpoint on the map, press "Insert into task" from the pop up.*
That'll insert the TP between my present location and the next TP.*
If it must be between TP2 and TP3, I can simply wait until passing
TP2 before touching the desired TP.
airport rather than predefined tasks.* Having said that, I rarely
touch my Streak as it always shows the information that I want to
see.* I programmed these selections on the ground about 4 years ago
and they still suit my needs.
consequence.* If it worked back then and wasn't "maintained", it'll
still work just the same way.* Of course, it hasn't been "improved"
but so what?* People set world records using that package as they
Robert
Dan Marotta
Dan Marotta
Right on, Dan. Flying with WinPilot Pro on an Avier I'm not missing any hand-holding and "support". It still works as good as it did back then.
Old May 6th 15, 08:41 PM posted to rec.aviation.soaring
jfitch
Robert
Dan Marotta
Dan Marotta
The theory that "if it works it will continue" to only is valid in a static system. If anything around it changes, then it may break, if unsupported it stays broken. There are a number of bugs in the Avier version of Winpilot that will never be fixed. Too bad, because it several areas (such as its thermal assistant or its depiction of Flarm traffic), it still has no equal)..
Old May 6th 15, 09:45 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Side note: interesting that I had to purchase a PC to run gliding software data logger software etc., (I am a Mac user) but there are no programs that run on the windows mobile OS. I have an iPhone for personal and an android for business, which I hate as it is so unintuitive. I use an old Windows phone for oversea travel and generally love the phone as it is so easy to work.
Old May 7th 15, 02:20 AM posted to rec.aviation.soaring
I have Parallels and Win7 on my MacBook just so I can run SeeYou. USB to serial dongle works just fine for the occasional ancient flight recorder.
-Tom
Old May 12th 15, 04:33 PM posted to rec.aviation.soaring
Somebody started developing an app two years ago, maybe someone else can finish and publish it?
https://github.com/Turbo87/skylines-ios-tracker
skylines down? Brad[_2_] Soaring 0 April 28th 15 05:01 AM
How are flights in SkyLines scored? kirk.stant Soaring 2 April 12th 14 08:43 AM
SkyLines Updates Tobias Bieniek Soaring 3 April 24th 13 07:33 AM
