There was is Nothing wrong with the language, it is the same as for the transponder requirement.
Within the 30nm arc defining the mode c veil, if the ceiling of the associated class b is 9000msl, you cannot climb above 9000 without the proper equipment. If the class b goes to 10,000msl, no problem, climb as high as you like to 17,999. You cannont fly over the top of Class B or Class C below 10,000 MSL. TFR the Class C tops out at 5,000, you cannot fly between 5,000 and 10,000 without equipment. Above 10,000 to 17,999 is fair game. BillT |
On Wednesday, May 6, 2015 at 11:11:33 PM UTC-4, Bill T wrote:
There was is Nothing wrong with the language, it is the same as for the transponder requirement. Within the 30nm arc defining the mode c veil, if the ceiling of the associated class b is 9000msl, you cannot climb above 9000 without the proper equipment. If the class b goes to 10,000msl, no problem, climb as high as you like to 17,999. You cannont fly over the top of Class B or Class C below 10,000 MSL. TFR the Class C tops out at 5,000, you cannot fly between 5,000 and 10,000 without equipment. Above 10,000 to 17,999 is fair game. BillT Bill, They might have wanted it to be the same as the transponder, but they used different language. The only way I can parse the FAR is that there is no exemption above 10,000 MSL. Todd 3S |
It's all in there, 91.225. Concentrate on (d)(2) and (d)(4) and (e).
(e) is your (d)(4) exemption for above 10,000 (e)(1) and (e)(2) applies to the 30nm veil referenced in (d)(2) Although it is not very clear. BillT |
On Thursday, May 7, 2015 at 11:26:53 PM UTC-4, Bill T wrote:
It's all in there, 91.225. Concentrate on (d)(2) and (d)(4) and (e). (e) is your (d)(4) exemption for above 10,000 (e)(1) and (e)(2) applies to the 30nm veil referenced in (d)(2) Although it is not very clear. BillT Where (e)2 apply is the problem. It's just not spelled out in the FAR. Todd |
On Thursday, May 7, 2015 at 9:26:53 PM UTC-6, Bill T wrote:
It's all in there, 91.225. Concentrate on (d)(2) and (d)(4) and (e). (e) is your (d)(4) exemption for above 10,000 (e)(1) and (e)(2) applies to the 30nm veil referenced in (d)(2) Although it is not very clear. BillT Yeah, frankly it is a mess. How can you tell from the language that (e)(1) and (e)(2) apply to (d)(2), but not (d)(4)? It says ALL operations authorized by this section. But another real problem for many western operations is the (e)(2). If it is real, it means that gliders cannot operate above 10,000 feet within the veil without ADS-B OUT, even if clear of the lateral boundaries of the Cass B. This will affect a good number of us in the west. |
On Friday, May 8, 2015 at 12:14:02 PM UTC-4, 2KA wrote:
On Thursday, May 7, 2015 at 9:26:53 PM UTC-6, Bill T wrote: It's all in there, 91.225. Concentrate on (d)(2) and (d)(4) and (e). (e) is your (d)(4) exemption for above 10,000 (e)(1) and (e)(2) applies to the 30nm veil referenced in (d)(2) Although it is not very clear. BillT Yeah, frankly it is a mess. How can you tell from the language that (e)(1) and (e)(2) apply to (d)(2), but not (d)(4)? It says ALL operations authorized by this section. But another real problem for many western operations is the (e)(2). If it is real, it means that gliders cannot operate above 10,000 feet within the veil without ADS-B OUT, even if clear of the lateral boundaries of the Cass B. This will affect a good number of us in the west. It's pretty clear that the intent of the rule is to permit gliders to operate above 10K ft without ADS-B OUT. By the time 2020 rolls around this might be a moot discussion. Hopefully, we'll have some very affordable gear by then so the main obstacle for voluntary equipage will go away. |
The 30 nm Mode C Veil does not exist above 10,000 MSL.
Sailplanes currently in production?? | [email protected] | Soaring | 0 | November 10th 11 01:02 AM |
LS-1 sailplanes in the USA | Burt Compton - Marfa | Soaring | 2 | November 2nd 10 12:08 AM |
Please ID 3 sailplanes | Every time | Soaring | 4 | August 20th 08 09:34 PM |
Cheap sailplanes | tango4 | Soaring | 100 | December 21st 04 08:21 PM |
50+:1 15m sailplanes | Paul T | Soaring | 92 | January 19th 04 01:59 AM |
