Discus/DG-300 performance difference
Old May 9th 15, 02:47 AM posted to rec.aviation.soaring
Default Discus/DG-300 performance difference
On Friday, May 8, 2015 at 6:20:38 PM UTC-7, wrote:
Hi All
I'm currently in the market for my first glider and am looking at standard class machines of the Discus/DG-300 era. Having read the Johnson tests and many posts on this forum, I'm a bit confused as to where the touted performance difference comes from though. Dick Johnson found the polars to be near enough to identical and demonstrated so with a figure overlaying them in the DG-300 article. Despite that though, there seems to be a feeling in this forum that the Discus is a superior machine and competition results seem to support that. Given the extremely similar glide performance, is there some other factor which makes the Discus a better performer or are it's superior competition results simply because better/more competitive pilots bought it?
You'll get a lot of opinions, so here's mine. I've had about 50 hours in a Discus, 40 in a DG-300, and 300 or so in a DG-303 (which is really a minor tweak, mostly the addition winglets). The Discus is easier to fly well, lighter controls (particularly pitch), basically flies itself in thermals, has wing tanks for easy filling, and has a higher wing loading at gross. The DG has a more robust structure, better gelcoat, tougher landing gear with more ground clearance, lands more slowly (meaning shorter off-field landings), climbs slightly better with comparable wing loading, and has a more comfortable cockpit. One key factor, DIscus is still well supported by SH for free, DG requires paying an annual tax to them if you want such niceties as parts and technical bulletins. Never flew any contests in a Discus, but did in the 303. I never felt at a disadvantage against a Discus, in climb or head to head final glides.
Marc
Old May 9th 15, 07:01 AM posted to rec.aviation.soaring
WaltWX[_2_]
I have close to 1000 hours in first a DG-300 followed by my Discus B flying cross country and competitively. My impressions mirror Marc's pretty close.. The DG-300 climbed well heavy but wouldn't run quite as well at higher speeds compared to the Discus B. Gel coat quality, pilot comfort and ruggedness all fall in favor of the DG-300. It has a smoother heavier car feel... probably because of the higher mass wings. The Discus B felt lighter and more responsive while maneuvering for thermals... also probably due to the lighter wing inertia mass.
A well flown DG-300 will do quite well against someone in a Discus B. But, as George Moffat said... even small performance differences add up for every minute of flight and the Discus will out perform a DG-300 in the long run.. But now, we have handicapped Club and Sport Classes, so either ship is competitive in those classes.
I like the SH factory and dealer support without the "DG Tax".
Very happy now with my Discus 2A.
Walt Rogers WX
What the difference between the Aluckyguess Piloting 14 April 6th 07 03:25 AM
what a difference! Chris Piloting 3 January 12th 06 11:52 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
