Getting out of the clouds in a Ventus C
Old May 10th 15, 05:26 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Getting out of the clouds in a Ventus C
Update on test #2
Logger showed descent rate to be between 1500-2900 fpm. Turn rate was about 45 seconds per turn.
Matt
Old May 10th 15, 06:13 PM posted to rec.aviation.soaring
waremark
And if you try the more generally recommended approach of airbrakes out, hands and feet off? That seems to work in both the gliders I most often fly.
You should enter the recovery mode from an unusual attitude since you will probably be in an unusual attitude very soon after losing external visual reference.
Unless I have reason to think the cloud goes down to the ground, I would not consider bailing out unless/until the wings come off.
Old May 11th 15, 11:49 PM posted to rec.aviation.soaring
Dan Marotta
You shouldn't be in an unusual attitude soon after losing visual
reference unless you immediately begin wiggling the stick around. If the
controls stay pretty much where they were, the glider should maintain
the same attitude, more or less. But then I only have a paltry 42 years
experience with instrument flying...
Dan Marotta
Old May 10th 15, 06:31 PM posted to rec.aviation.soaring
Richard[_9_]
On Sunday, May 10, 2015 at 9:26:20 AM UTC-7, Matt Herron Jr. wrote:
Update on test #2
Matt
Matt,
To be realistic and get a true sense of what will happen please do this with you eyes closed.
Richard
Old May 11th 15, 01:50 AM posted to rec.aviation.soaring
Matt Herron Jr.
You first, smart guy.
Old May 11th 15, 02:26 PM posted to rec.aviation.soaring
Richard[_9_]
Matt,
Seriously once you go into a cloud you will have no visual references. After about 30 seconds especially with the maneuver described you will have vertigo. What happens when you get out of the cloud? To establish your visual reference again may take another 30 seconds depending how serious the vertigo and what you do when you experience this. Things may get much worse. It is not just the aircraft that is the issue.
Richard
Pyrocumulus clouds over CA son_of_flubber Soaring 0 August 7th 14 09:49 PM
Clouds bildan Soaring 9 December 20th 08 09:08 PM
PH-GRD breaking through the clouds Tom Hayden Aviation Photos 0 October 2nd 07 08:40 PM
How clouds are made Glenn[_2_] Aviation Photos 1 October 2nd 07 05:28 AM
