alternative to iGlide for iPhone (6 plus)
  #31
Old May 15th 15, 04:26 PM posted to rec.aviation.soaring
Bob Pasker
Default alternative to iGlide for iPhone (6 plus)
here's another bug I filed today.
Aktualisiert von: Marc Förderer, 15. Mai, 17:21:
Hi,
I have. It can be resolved with changing the filter (as a workarround).
We'll change that. Thanks for the help!
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 17:20:
lite on iphone6
have you been able to reproduce?
Aktualisiert von: Marc Förderer, 15. Mai, 16:05:
(If you set the data filter to lets say 3000km, you will of course be able to work around that, yet this is not what we want / no general solution)
Marc
Aktualisiert von: Marc Förderer, 15. Mai, 15:57:
What version do you use? Which device?
I suspect iGlide lite on iPhone?
Sorry for the guessing.
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:54:
also, i don't know if I can reproduce the problem without taking another 1500km trip!
On May 15, 2015, at 8:52 AM, Bob Pasker wrote:
Am I missing something?
Aktualisiert von: Bob Pasker, 15. Mai, 14:53:
Sent from my iPhone
Aktualisiert von: Marc Förderer, 15. Mai, 14:46:
What happens if you go to Menu route clear route?
Will it "work" afterwards?
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:40:
There should never be any reason why I can't clear the destination! But the answer is yes it had a GPS lock.
Sent from my iPhone
Aktualisiert von: Marc Förderer, 15. Mai, 14:31:
In the second city, did you have a current position in iGlide? Was there a GPS-Signal?
A reason for this behavior would be that iGlide did not get a current GPS position.
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 14:04:
i don't understand the question. I flew from one city to another. when I turned on iGlide, i could not clear the previous destination
Aktualisiert von: Marc Förderer, 15. Mai, 13:51:
maybe I got you wrong, did you have a valid position after being 1500km away?
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 13:46:
its not intended to be used in two different places?
Aktualisiert von: Marc Förderer, 15. Mai, 13:45:
Hi Bob,
thanks for the info. We'll fix that, but well, the app is not intended for this purpose.
Cheers
Marc
Aktualisiert von: Bob Pasker, 15. Mai, 13:23:
1. set a waypoint X as a destination in iGlide
2. do a bunch of soaring
3. with the destination still turned enabled, turn off the app
4. fly commercial aircraft to another city 1500km away
5. turn on the app
6. destination X remains selected, destination is 1500km away.
7. touch "NEAREST" to select a new destination. all nearby waypoints are invisible because the data filter is set to 500km, so all you see are airports 1,000km away
the only way I found to clear the fix was to delete the app and reinstall it, which of course deleted all of my data/preferences
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iPhone 6 Plus and iGlide jfitch Soaring 39 May 20th 15 01:07 AM
iGlide Mike Rinaldi Soaring 4 April 28th 15 12:48 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
