Slow tow with full water?
On Sunday, May 17, 2015 at 2:43:09 PM UTC+1, Craig Funston wrote:
Slow tow with full water? I don't know anything about the circumstances but there has been an advisory email to all owners to emphasise the need to make sure that tug pilots are briefed that the minimum aerotow speed for a fully ballasted JS1C/21m is 70 knots (130 km/h) in turbulent conditions. The minimum in calm conditions is 65 knots. The wingloading of a 21m JS1 at the MAUW of 720Kg is 58.7kg/m2 which is higher than any other glider that is likely to be regularly aerotowed in any numbers. The only other production gliders with similar max wing loadings are the Quintus and the EB29 with its shortest 25.3 tips (which are all self launchers) and the Antares 23T of which there are not likely to be many. It is this unusually high wingloading that needs to be fully appreciated at both ends of the tow rope IMHO. John Galloway |
On Sunday, May 17, 2015 at 3:34:34 PM UTC+1, wrote:
On Sunday, May 17, 2015 at 2:43:09 PM UTC+1, Craig Funston wrote: Slow tow with full water? I don't know anything about the circumstances but there has been an advisory email to all owners to emphasise the need to make sure that tug pilots are briefed that the minimum aerotow speed for a fully ballasted JS1C/21m is 70 knots (130 km/h) in turbulent conditions. The minimum in calm conditions is 65 knots. The wingloading of a 21m JS1 at the MAUW of 720Kg is 58.7kg/m2 which is higher than any other glider that is likely to be regularly aerotowed in any numbers. The only other production gliders with similar max wing loadings are the Quintus and the EB29 with its shortest 25.3 tips (which are all self launchers) and the Antares 23T of which there are not likely to be many. It is this unusually high wingloading that needs to be fully appreciated at both ends of the tow rope IMHO. John Galloway Moving away from the subject of crashes momentarily (I hope!) - i'm test flying a JS-1 on Saturday if the weather in the UK is kind. It'll be unballasted and likely in 18m mode. I'm just a little bit excited. |
Jim I've got a couple short flights in a dry 18m JS1. You'll be smiling for weeks.
On Monday, May 18, 2015 at 8:03:20 PM UTC+2, Tony wrote:
Jim I've got a couple short flights in a dry 18m JS1. You'll be smiling for weeks. You're absolutely right - I'm still grinning whenever i think about it...which is pretty much all the time ![]() |
![]() Quote:
https://easa.europa.eu/system/files/...2-20022008.pdf I wonder how well it handles that load on tow |
![]() Quote:
I've also had a clubmate recount a tow pilot declaring he was already towing fast enough when he was calling for more speed in his heavily loaded ship while launching at another club. Both occasions were experienced tow pilots so there was some sort of disconnect going on. There are 3 JS1s here at the one club in NZ, 2 are JS1-C 18/21 and the other one a B. I must ask of their experiences tow wise when I next visit Last edited by Ventus_a : May 19th 15 at 12:46 AM. |
Houston crash today | [email protected] | Soaring | 50 | July 17th 14 08:49 PM |
Houston'ers- EYQ or IWS? | Shawn | Piloting | 11 | June 15th 04 05:52 AM |
Houston Area Air Crash | Ludlow Johnson | Piloting | 2 | November 20th 03 03:10 PM |
Wildcat crash in Houston | Wright1902Glider | Home Built | 3 | October 27th 03 09:24 PM |
Wildcat crash in Houston | Wright1902Glider | Restoration | 0 | October 21st 03 03:38 AM |
