WTB: Discus B or CS Winglets
Old May 20th 15, 02:46 PM posted to rec.aviation.soaring
Dan Marotta
Default WTB: Discus B or CS Winglets
If you're really serious, you might be able to do that using an FAA Form
337.
https://www.faa.gov/forms/index.cfm/...umentID/185675
On 5/19/2015 10:11 PM, Ross wrote:
On Tuesday, 19 May 2015 18:49:20 UTC+2, JS wrote:
There's a winglet kit for Discus B/CS on the M+H website.
http://mandhsoaring.com/forsale.html
Better than original. Aren't the Maughmer winglets approved mods?
Hi Jim,
If only it were that easy here.
The only certified winglet is the std winglet. I would happily change if I was legally allowed to do it.
Ross
Dan Marotta
Old May 21st 15, 11:01 AM posted to rec.aviation.soaring
Ross[_3_]
Hi Dan,
Based in the USA it would be easy enough.
Based in Europe like I am it makes it basically impossible. However the idea to help someone upgrade is a very good idea. Thanks Jim
Old May 21st 15, 04:35 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, May 21, 2015 at 5:01:52 AM UTC-5, Ross wrote:
Hi Dan,
Ross, maybe you could get an inspector that doesn't know the difference and just install the M&H set? :-)
Old May 21st 15, 04:53 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Or you could live with the fact that you're not losing much in the way of
performance, have a better handicap & use less tape & time to rig in the
morning.
If I was flying in a handicapped comp I would definately fly without the
winglets.
And before you ask, No I won't sell you either of my sets.
Regards
Kevin
G-DJAH
G-KOBH
Hi Dan,
and
Old May 21st 15, 11:58 PM posted to rec.aviation.soaring
JS
For those unfamiliar, these must be for the glider with the creative registration:
D-KCUF
Built from a crashed Discus, best to read the registration backwards.
Hey Ross, are you back from NZ?
Hadn't looked at the original sender details!
By the way, my friend who bought the FSG2T is very happy with it.
New Ventus 2 and Discus Winglets - M&H Alpha Eight Soaring 11 February 21st 12 04:41 PM
Discus Winglets Peter F Soaring 8 December 12th 05 04:29 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
