But I feel that encrypting the protocol goes against the spirit with
which I, and many other early adopters made risk investments. As a matter of fact a FLARM customer might very well receive this communication soon: "Dear Flarm customer, as already announced four years ago the new firmware release 6.0 prevents DSX devices from exchanging position, speed and altitude data with our products operating this release. In case of a mid air collision we do not take responsibility for the DSX pilot as he/she chose to buy an incompatible device. As for that one of our customers, who will happen to be involved in accident we sincerely apologize for the inconvenience. Thanks for choosing FLARM." |
ROTFL
The T-Advisor AND Flarm are NOT anticollision system.
Anticollision systems are those who tell the pilot what to do (like TCAS), in case of emergency. Neither system does this. BOTH systems are NOT anticollision systems. Cleared this, those who talk about the "predictive algorithm", can please explain: 1) how it works, since they must know how it works, to be in the position of saying that it works or it doesn't 2) how they know that such an algorithm has been implemented into a Flarm system: what proof do they have of this ? 3) if they have ever seen the trace of at least 10 glider flights in different conditions (competition, cross country, around-the-airfield, ridge soaring,....); whoever has seen some, not many, traces of flights, without the need to be a glider pilot, can understand that a prediction of the position of a glider in a future time beyond a fistful of seconds is impossible, exactly IMPOSSIBLE, since not even its pilot knows it, apart from some cases, like straight flying and constant turn rate thermaling. A glider pilot knows that he will be changing the trajectory of the glider to search for the best netto value, which depends on the micro air movements, which are unknown to the pilot in terms of exact location. Is there a machine capable of predicting these locations ? And even if there was, is there a machine capable of predicting what a glider pilot will do in the next 30-60-80 seconds ? Because this is what the rumored (never verified) "prediction algorithm" does. This is spectacular indeed ! 4) even if they found a system to predict the position of the glider with a certain probability, would they trust as optimal a system that has (obviously) a probability to fail the prediction and miss a danger of collision ? Even if the probability was low (all but sure, since never demonstrated with objective tests and calculated data), 2, 3, 10 collisions (and deads) out of XX'XXX flights are too much. In aeronautics, this approach is wrong: this is not the way we work in professional aeronautics, that has taken us where we are in aviation Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? Please indicate the source of this concept. Because this is completely FALSE. The T-Advisor does NOT USE (not that it does not calculate, a very different story) a prediction coming from an unverified, unknown algorithm (if it is at all) to give warnings to the pilot. Its approach is down to what is sure, real, objectively undeniable and at the basis of a collision: the relative approach speed of the aircraft and their distance, calculating the time to possible impact. Depending on some parameters (time to impact, approach speed, difference of altitude, etc.) the communication to the pilot is given at three different levels of warning. No predictions based on extrapolations or assumptions of pilot's behavior, that are impossible to know beforehand. Nevertheless, to make the Flarm systems work with the T-Advisor, it calculates the prediction in a very similar way to these systems, and transmits the data. But it does not, and will not use these hypothetical data to give warning of a possible fatal collision to a pilot. The consistent behavior of the Flarm systems flying with the T-Advisor systems like with other Flarms has demonstrated, in some hundreds thousand hours of flight, that the prediction of position calculated by the T-Advisor is very similar to the one calculated by the Flarm. I will not say here how this is done, because it might destroy your faith (on not proved basis) in what was always told to you, but this is enough to prove that the two systems work well together, and the same could happen with other new systems around. The reports of many pilots, during 10 years of operations and the hundreds thousand hours of flight of the T-Advisor are a clear demonstration that it is just an excuse that two different systems can't work well together. Apart from all the above, Kevin, there is NO PILOT that can see all air traffic of gliders within a range of up to 17 km (this is the maximum range of the T-Advisor correctly installed onboard). If you are capable of that, you are the only one, and you are an outlayer when considering the behavior of the average glider pilot. Tango Eight, your statement is lacking of a scientific base: WHAT demonstrates that the "prediction algorithm works very well" ? Not the number of hours. That is senseless, obviously. The collisions avoided thanks to the system would demonstrate that. So: have you got the statistics "before and after" the introduction of these systems ? Do you know if these systems have failed anytime ? And why ? (There have been collisions between gliders equipped with Flarm). Obviously these systems increase the awareness of the surrounding traffic, there is no doubt about that, but from this to saying that it demonstrates that the prediction algorithm is correct the step is huge, and scientifically honestly, impossible. The technical chats without FACTS are of poor use. If anybody wants to convince somebody else of something in aviation, and engineering in general, should do it with FACTS, not declarations without basis. Prediction algorithm ? Patented method from Onera implemented ? Who proved that it's implemented ? (btw: discussing with Mr. Le Tallec, the inventor of the "prediction method" rumored to be adopted in these systems, he agreed that his method doesn't work well in ridge soaring, where the only method that is sensible is the one based on the approach speed and distance). A radio protocol copyrighted or patented ? (It is impossible, by law) Assigned patents ? (Make a check first: you will find only one, valid just for Germany, accepted after it was refused twice - Nothing more). This way of working has been and still is very far away from what is a sounding procedure in aeronautics. This doesn't mean spending the money to certify a system (which, btw, with so many units around, could be spent, no ?). - It means adopting a procedure that is sound and clear, in the design (not starting with an electronic design that is old and, i.e. without the proper radio performance: the declared range of that system was 3 km - written in the official presentation of 2005 - while the T-Advisor was reaching 15 km, with the same transmission chip and power output) - What is used for safety has to prove its full effectiveness with facts and objective quantitative tests (marketing doesn't save lives) - What is used for safety has to be verified by an independent party, not hidden (who hides it, is because he fears to be uncovered, usually; patents protect what can be be protected, the rest is fog and chats) - When a firmware update is mandatory, it must be managed in a way that there isn't a situation of a part of the systems (of the same manufacturer) incompatible with the rest of the same systems, creating a situation of high risk (for example for a change of radio protocol, it can be done with three lines of code like this: if (date XX); transmit like this; else transmit like that). The origin of the discussion appears to be a commercial attitude of Flarm. They are perfectly right in doing what they do: they are not a charity foundation and they try to protect what they did in all ways possible. It is then up to the sector (gliding) and customers to accept this or not. It is then up to the authorities to make and impose the rules for the well being of the community and the continuous development. What is sure is that what has happened until now is far from the standard practices adopted in aeronautics (and in many ways, engineering in general): it's not a matter of increasing costs (the excuse so often brought up to scare people), it is about being capable of acting according to principles established during decades of (sometimes tragic) history of aviation. Forgetting these principles might bring something quick today (as it has happened for this topic), but it will be painful tomorrow, when a correction to the path is required. Better founding it well as soon as possible and keep on along a way that has made aviation safe. |
Since you ask...
The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? |
Il giorno mercoledì 27 maggio 2015 12:45:08 UTC+2, Kevin Neave ha scritto:
Since you ask... The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? Kevin, I honestly do not understand why you are so emotional about this topic. No one is trying to convince you that you should trash your device, nor that's the aim of the petition. But you have to take that some other may prefer a T-Advisor. I personally prefer the T-Advisor because I like better its clock and because I agree with the philosophy behind its warning algorithm. If you ask though "how many gliders in Europe are using a DSX", well, I remind you that was it only one, yet makes you Flarm's policy one of the flarm customers that may die in a mid-air collision with a DSX pilot. You have to agree this is a very unusual way of "customer caring". |
Since you ask... The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? ....besides, are you really sure that all the flarms Flying around you are updated to version 6.01 and therefore that you can see them and been seen? regards |
On Wednesday, May 27, 2015 at 12:45:08 PM UTC+2, Kevin Neave wrote:
Since you ask... The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? Kevin, I understand that the sentence can be read in a way different from what was intended: the T-Advisor notifies the pilot of the NEW presence of a glider within range. It blimps once, to tell the pilot that there is a glider there, and will not continue indicating it to the pilot (how could it indicate continuously all gliders in range, on a led display ? Obviously this is impossible, beside useless). Your comment derives from the fact that you have not had the chance of flying with a T-Advisor, otherwise you would have noticed how it works. Way differently from what you think. But you have forgotten to read the rest of the manual, where it is clearly specified that the system warns the pilot only about gliders that are going to possibly collide. All pilots with T-Advisor, that has been developed with the input of all of them, are extremely happy to be notified when a glider enters the operating range of the system: it is very helpful to spot another glider at a quite long distance, not mainly for collision avoidance but for information. Also in competitions. Therefore, the T-Advisor doesn't keep beeping for *any* aircraft in range, buto only for those that are close to possibly collide, warning the pilot with different levels of beeps and led flashes depending on the severity of the situation. This doesn't mean it decides which plane is more dangerous: it tells you what planes are going to hit you based on the approaching speed/distance = time to impact. The warnings are prioritized according the time to impact. The pilot decides, ultimately. What it doesn't is to decide which threat to display and which not, based on a "prediction", that, I reiterate, is impossible for a glider not flying with a regular trajectory (straight of stable rate of turn - it's enough to look at the glider traces of any flight to understand this). I think that your worries are |
On Friday, May 29, 2015 at 10:41:02 AM UTC+2, Lucas wrote:
On Wednesday, May 27, 2015 at 12:45:08 PM UTC+2, Kevin Neave wrote: Since you ask... The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? Kevin, I understand that the sentence can be read in a way different from what was intended: the T-Advisor notifies the pilot of the NEW presence of a glider within range. It blimps once, to tell the pilot that there is a glider there, and will not continue indicating it to the pilot (how could it indicate continuously all gliders in range, on a led display ? Obviously this is impossible, beside useless). Your comment derives from the fact that you have not had the chance of flying with a T-Advisor, otherwise you would have noticed how it works. Way differently from what you think. But you have forgotten to read the rest of the manual, where it is clearly specified that the system warns the pilot only about gliders that are going to possibly collide. All pilots with T-Advisor, that has been developed with the input of all of them, are extremely happy to be notified when a glider enters the operating range of the system: it is very helpful to spot another glider at a quite long distance, not mainly for collision avoidance but for information. Also in competitions. Therefore, the T-Advisor doesn't keep beeping for *any* aircraft in range, buto only for those that are close to possibly collide, warning the pilot with different levels of beeps and led flashes depending on the severity of the situation. This doesn't mean it decides which plane is more dangerous: it tells you what planes are going to hit you based on the approaching speed/distance = time to impact. The warnings are prioritized according the time to impact. The pilot decides, ultimately. What it doesn't is to decide which threat to display and which not, based on a "prediction", that, I reiterate, is impossible for a glider not flying with a regular trajectory (straight of stable rate of turn - it's enough to look at the glider traces of any flight to understand this). ..... I think that your worries are Sorry: it was posted inadvertently, before completion: I think that what worried you is clear now. Again: pity you hadn't got the chance of flying with a T-Advisor. Most T-Advisor pilots have been reporting their satisfaction about how the system warns them about surrounding traffic and risk of collisions. None of them has ever said that it's annoying in thermals and has to turn down the volume. And this is another difference to the other system. All of them reported that the function that informs them about the position of another plane entering into the range is very useful. Many T-Advisor pilots are ex-Flarm pilots. |
We wish to thank everybody. We have some 900 pilots (and are growing) that think that the protocol should be free and then everybody is free to buy the system he prefers!
No monopoly, especially on security. IGC should agree with this. THANKS AGAIN |
On Friday, May 29, 2015 at 4:40:38 AM UTC-5, Lucas wrote:
On Friday, May 29, 2015 at 10:41:02 AM UTC+2, Lucas wrote: On Wednesday, May 27, 2015 at 12:45:08 PM UTC+2, Kevin Neave wrote: Since you ask... The first hit from Google for "dsx systems t-advisor" is http://frank.schellenberg.nl/wp-cont...r_07_12_19.pdf This states.. "The Traffic Advisor, notifies the pilot the presence of all planes that enter within the radio operating range (that for the T-Advisor is up to 7 km)" I may be dim but I read that as "T-Advisor tells you 'that there are lots of gliders flying within 7 km' ". So I'll rephrase that. It *would* tell me that there are lots of planes flying within 7km of me if they were fitted with DSX. The aircraft I'm interested in are the ones that are that are converging with me. Flarm warns me of these as long as they are also Flarm equipped Flarm is intended as an aid to lookout, generally I've seen most contacts by the time Flarm generates a warning, occasionally I get a wake up call. Flarm reminds me that my lookout is not as good as it could be. (Of course I have no idea how many I'm missing and Flarm isn't picking up) I don't see what T-Advisor would give me A large number of the gliders flying XC in the UK (possibly a majority by now) are using Flarm. I don't know of ANY using DSX. So I repeat the question, how many gliders in Europe are using DSX? Or more specifically how many in the UK are using DSX? KN At 23:44 26 May 2015, Lucas wrote: Kevin Neave, can you show in which website you read that the T-Advisor tells you "that there are lots of gliders flying within 7 km" ? Kevin, I understand that the sentence can be read in a way different from what was intended: the T-Advisor notifies the pilot of the NEW presence of a glider within range. It blimps once, to tell the pilot that there is a glider there, and will not continue indicating it to the pilot (how could it indicate continuously all gliders in range, on a led display ? Obviously this is impossible, beside useless). Your comment derives from the fact that you have not had the chance of flying with a T-Advisor, otherwise you would have noticed how it works. Way differently from what you think. But you have forgotten to read the rest of the manual, where it is clearly specified that the system warns the pilot only about gliders that are going to possibly collide. All pilots with T-Advisor, that has been developed with the input of all of them, are extremely happy to be notified when a glider enters the operating range of the system: it is very helpful to spot another glider at a quite long distance, not mainly for collision avoidance but for information. Also in competitions. Therefore, the T-Advisor doesn't keep beeping for *any* aircraft in range, buto only for those that are close to possibly collide, warning the pilot with different levels of beeps and led flashes depending on the severity of the situation. This doesn't mean it decides which plane is more dangerous: it tells you what planes are going to hit you based on the approaching speed/distance = time to impact. The warnings are prioritized according the time to impact. The pilot decides, ultimately. What it doesn't is to decide which threat to display and which not, based on a "prediction", that, I reiterate, is impossible for a glider not flying with a regular trajectory (straight of stable rate of turn - it's enough to look at the glider traces of any flight to understand this). .... I think that your worries are Sorry: it was posted inadvertently, before completion: I think that what worried you is clear now. Again: pity you hadn't got the chance of flying with a T-Advisor. Most T-Advisor pilots have been reporting their satisfaction about how the system warns them about surrounding traffic and risk of collisions. None of them has ever said that it's annoying in thermals and has to turn down the volume. And this is another difference to the other system. All of them reported that the function that informs them about the position of another plane entering into the range is very useful. Many T-Advisor pilots are ex-Flarm pilots. Ok, so finally it all boils down to: a small group of Flarm users don't like the Flarm display setup, and want something less intrusive. So instead of DSX licencing the Flarm protocol and using their own display logic, they come up with their own system - despite the fact that there is already a huge installed base of Flarm users. So now that Flarm decides to encrypt their protocol (due to the OGN hacking and privacy issues), suddenly DSX T-advisor users are out in the cold. Hmm, anyone remember VHS vs BetaMax? Best system doesn't always win - but when only one system is left, it becomes the de-facto protocol! Kirk |
Collision Avoidance Systems for gliders | noel56z | Soaring | 21 | March 15th 07 01:45 AM |
Collision Avoidance Systems | jcarlyle | Soaring | 27 | September 7th 06 03:38 AM |
Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 10:15 PM |
Anti collision systems for gliders | Simon Waddell | Soaring | 2 | September 21st 04 08:52 AM |
Anti-collision lights | Grandpa B. | Owning | 4 | August 8th 03 06:27 AM |
