Collision Avoidance Systems for gliders
Old March 6th 07, 10:33 PM posted to rec.aviation.soaring
noel56z
Default Collision Avoidance Systems for gliders
After reading of the recent mid-air out West I bought a Zaon MRX PCAS
(Portable Collision Avoidance System) from Aircraft Spruce &
Speciality to try out. I also fly a Piper Vagabond without an
electrical system and this unit doesn't require your aircraft have a
mode C transponder as it's a passive system using the Mode C readout
from another airplane. The unit has a build in electronic altimeter
which compares the Mode C readout of the "target" a/c and gives you a
"relative" altitude difference and approxiamate range. I used it
locally on the ground and observed the readout of a Piper Cherokee
on downwind at the local airport..turn base and
final........amazing!!! Although this unit doesn't give you a bearing
to the target it does give you the altitude and range which sure gives
you some warning. They have a web site http:zaonflight.com which has
an online manual, etc.
Noel Anderson
Schweizer 1-26E
Collision Avoidance Systems jcarlyle Soaring 27 September 7th 06 04:38 AM
Collision Avoidance and ATC Bubba Soaring 5 September 1st 06 05:31 AM
Collision Avoidance Systems [email protected] Products 0 May 21st 06 11:15 PM
Collision avoidance device Jim Hendrix Soaring 1 October 19th 04 10:24 AM
Anti collision systems for gliders Simon Waddell Soaring 2 September 21st 04 09:52 AM
