On Thu, 28 May 2015 04:58:00 -0700, mzivley wrote:
This past weekend, with the glider in the hanger, the Zaon alerted to every single towplane departure. PowerFlarm scored a zero. Nothing. As a user of a bog-standard Euro FLARM system, I'd be surprised if my unit did light up of beep while its stationery and on the ground. Thats because the standard FLARM is designed to avoid transmitting and showing alerts while it is stationery on the ground. Are you sure that the PowerFLARM doesn't do the same? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Transponder: Mode-C or Mode-S? | Morteza Ansari | Soaring | 27 | April 17th 19 05:02 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported | Paul Remde | Soaring | 24 | January 22nd 12 01:50 AM |
LK8000 Portrait mode in PC sim mode | kirk.stant | Soaring | 22 | December 28th 11 02:25 PM |
PowerFLARM Mode S question | kirk.stant | Soaring | 54 | October 26th 10 02:51 PM |
