What could cause extremely high effort to release a Tost CG hook on aTwin Astir?
Old June 1st 15, 03:31 PM posted to rec.aviation.soaring
Bill D
Default What could cause extremely high effort to release a Tost CG hookon a Twin Astir?
On Monday, June 1, 2015 at 7:26:07 AM UTC-6, JJ Sinclair wrote:
Is it a two tow-hook system?
Yes
Many G-103's removed the CG hook and replaced it with a dummy block. Was the re-installation proper?
I can't determine that from the maintenance log but it's worth checking.
Look for an obstruction resulting in the nose hook reaching full open and not leaving CG hook sufficient movement to open.
That was my first thought too but I've been lectured that the Twin Astir works differently.
Check by removing CG cable (at hook), then actuating release system. Look for improper CG hook, improper installation, not enough cable movement at CG hook.
Hope this helps,
It helps a lot JJ
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
needed!! drawings/data for Tost hook for Pawnee thing73 Soaring 3 November 13th 09 02:14 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
