On Tuesday, June 2, 2015 at 12:00:06 PM UTC-5, Kevin Neave wrote:
Hi Dan It obviously works for you but I'm interested in why you do this. If you're doing a 180 to finals and opening the airbrakes at the start of the turn are you not pointing away at this point with the landing area out of sight behind you? Kevin, Dan is just doing what he was taught as an Air Force pilot - single steep 180 turn from downwind to final. In many ways the easiest way to land a plane - when combined with an overhead pattern (which doesn't really work well with gliders, unfortunately) results in the exact same pattern at every landing. A shame civilian pilots are not exposed to it. Works great in a Pawnee - 120mph at 500 agl on initial, pitch out just past the numbers, configure on downwind, pull off some power and a nice descending 180 turn will put you on the numbers in minimum time - and it looks good from the ground! Kirk 66 |
Peugeot video turns into a glider ad | JS | Soaring | 0 | September 29th 09 05:36 PM |
Debunking 911 | The Endeavor | Naval Aviation | 0 | April 22nd 09 12:23 PM |
It's Da' Spin,Boss! Da' Spin! | [email protected] | Home Built | 8 | November 19th 08 10:28 PM |
Glider Stall Spin Video on YouTube | ContestID67 | Soaring | 13 | July 5th 07 08:56 AM |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
