Debunking Glider Spoiler Turns Causing Spin Thinking
Old June 2nd 15, 09:44 PM posted to rec.aviation.soaring
kirk.stant
Default Debunking Glider Spoiler Turns Causing Spin Thinking
On Tuesday, June 2, 2015 at 1:37:48 PM UTC-5, Tango Eight wrote:
On Tuesday, June 2, 2015 at 1:24:53 PM UTC-4, kirk.stant wrote:
Bottom line, I think it helps to get everything set on downwind (gear, flaps, initial spoiler setting, airspeed) then concentrate on flying a safe pattern. To me, messing with flaps and spoilers while making base and final turns and changing aircraft configuration throughout the pattern is asking for trouble (see all the ASW-20s that crashed early on with the gear cycling on final, ex-Libelle pilots thinking they were pulling the spoilers!)
What helps even more is starting with the POH before developing your own type specific procedures :-).
For instance: Landing flaps in the 20 are reserved for final approach, per the POH, for a whole bunch of very good reasons.
-Evan Ludeman / T8
Obviously, type-specific procedures specified in the POH take precedence. In the case of the LS6, it pretty much just says "for landing, put flaps in L". Having flown the 20, I totally agree with the POH procedure!
My point is that it's possible to make a landing pattern procedure so complicated that the pilot's attention is distracted "by doing everything in the right sequence at the right time" - forgetting that the most important thing is to arrive on short final at a suitable airspeed and height, and at the desired location!
Kirk
66
Peugeot video turns into a glider ad JS Soaring 0 September 29th 09 05:36 PM
Debunking 911 The Endeavor Naval Aviation 0 April 22nd 09 12:23 PM
It's Da' Spin,Boss! Da' Spin! [email protected] Home Built 8 November 19th 08 10:28 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
