Jet turbine reliability
Old June 3rd 15, 08:26 AM posted to rec.aviation.soaring
krasw
Default Jet turbine reliability
On Tuesday, 2 June 2015 21:40:56 UTC+3, wrote:
On Tuesday, June 2, 2015 at 7:34:47 AM UTC-7, krasw wrote:
Surely jet engine cannot be more unreliable than Solo two-stroke that you need to dive to start. If it would, you would be lucky to start it even once.
Solos don't need a dive to start. You can start them that way if your starter battery is dead but normally you never need to do this.
I was obviously talking about turbos, which you have to dive to start. There is only handful of turbos with electric starter (for some unimaginable reason).
There on single moving (rotating) part in a turbine. Compare that to shaking two-stroke held together with a bucket of tiewraps.
Old June 3rd 15, 09:05 PM posted to rec.aviation.soaring
Steve Parker[_2_]
Let's hope that that single rotating part has been made and assembled with
the proper controls.
Something rotating at 100,000 rpm about 3 feet from your head had better be
good.
Contained failure would mean bullets being fired at your fin/tailplane.
Uncontained failure and you had better have a good parachute, assuming you
survive the explosion!!
Old June 3rd 15, 10:04 PM posted to rec.aviation.soaring
Hazard is to the rear engine and its mounted behind you. I remember seeing that some of these also had a containment housing. So, I think they have addressed the issue. But it makes one heck of a pop if they do shed a blade! This will be about the only time a turbine will vibrate as it winds down..
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 04:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 07:50 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Reliability of O-300 Captain Wubba Owning 13 March 9th 04 12:17 AM
