Having flown a land-mower piston engine for quiet a while (ASW-24E) and
now having decided to go for the JS1 jet, I consider this a major step forward in terms of safety. Make no mistake, none of these engines is an aircraft engine in the sense used by airplane pilots. You should always expect that it will fail to start, or worse, quit at the most inappropriate time every single time you use it. Not doing so is simply foolhardy. The difference with the JS1 jet (and I imagine the similar shark installation) is that if the engine does not start, you are not stuck with a huge profile in the airstream and a glider that is descending like a rock. You simply flip a switch and about a minute later you are either climbing or continuing towards a perfectly normal off-field landing. This is much closer to the idea people have when they buy into a self-launcher or turbo, only to discover later that the reality is very different. It is a great sign of progress that now jet and electric technology are making this much more of a reality. On 03/06/2015 04:47, wrote: They are MODEL engines and are not "man rated" by the FAA. There are several YT vids showing how they are built and assembled. Watch these and then determine if you ever want to put your "skin on the line" using one. By comparison, the Williams FJ-44 is a small TURBOFAN originally built to power US cruise missiles. It had to demonstrate extreme reliability before it was FAA certified and man rated for use on very light business jets. Not to mention it was originally designed to stringent military specs. Bottom line again, these are model TURBOJET engines. Never put your safety/life in a position where their reliability matters. |
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power | TurbineMini Richard | Rotorcraft | 2 | January 28th 09 07:50 PM |
Turbine Duke or turbine Baron? | Montblack | Piloting | 1 | December 13th 05 04:54 PM |
Turbine Duke or turbine Baron? | [email protected] | Piloting | 26 | December 13th 05 07:50 AM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Reliability of O-300 | Captain Wubba | Owning | 13 | March 9th 04 12:17 AM |
