I would expect the QA on these units to be better than that of the typical model turbine. You'll be much less likely to run into a dud here. What is the retail price of this 420N turbine with ECU?
"They are MODEL engines and are not "man rated" by the FAA. There are several YT vids showing how they are built and assembled."
A very inappropriate comparison. It's akin to comparing an experimental aircraft with a certified, high capacity transport category aircraft. The Williams has undergone destructive testing, blade containment testing, is certified for flight into known icing, use on ground, use in rain etc etc. Using M&D's engine as an example, it has no accessory gearbox so no lubrication; you add extra oil to the fuel like a 2-stroke. It has no electrical system thus no self-sustaining fuel delivery nor command and control. Both of those functions are powered by the battery so it's essential to leave a battery untouched 'for Justin'. It's not approved for ground operation other than maintenance nor for flight in rain. It's a simple, elegant, low weight, low drag thrust source for sustaining. A 'getcha home jet' with only the operating principle as a similarity with Williams and other certified products. And thanks heavens for that! It would be too large, too heavy and too *EXPENSIVE* otherwise. CJ |
Chris is exactly right. The HPH Shark Jet uses a industrial
powerplant with over 700 made for UAV / Drone use, so maturity is high. Field reliability is very good with minimal issues... Normally a "one-off" re-tuning exercise. You mix turbine oil with JET A1 and this total-loss approach avoids the needs for a separate lubrication system. Drag on deployment is not noticable at all. The Engine management is achieved with a FADEC controller which leaves you with a single 'Throttle' knob on the panel. HPH have been shipping the Shark Jet for over 5 years now and into the UK Market (where I live) for about three years. With "Double-digit" Shark Jets in the UK I have never had to remove a Jet powerplant yet.... At 05:47 04 June 2015, wrote: "They are MODEL engines and are not "man rated" by the FAA. There are seve= ral YT vids showing how they are built and assembled." A very inappropriate comparison. It's akin to comparing an experimental air= craft with a certified, high capacity transport category aircraft.=20 The Williams has undergone destructive testing, blade containment testing, = is certified for flight into known icing, use on ground, use in rain etc et= c. Using M&D's engine as an example, it has no accessory gearbox so no lubrica= tion; you add extra oil to the fuel like a 2-stroke. It has no electrical s= ystem thus no self-sustaining fuel delivery nor command and control. Both = of those functions are powered by the battery so it's essential to leave a = battery untouched 'for Justin'. It's not approved for ground operation oth= er than maintenance nor for flight in rain. It's a simple, elegant, low wei= ght, low drag thrust source for sustaining. A 'getcha home jet' with only t= he operating principle as a similarity with Williams and other certified pr= oducts. And thanks heavens for that! It would be too large, too heavy and = too *EXPENSIVE* otherwise. CJ |
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power | TurbineMini Richard | Rotorcraft | 2 | January 28th 09 07:50 PM |
Turbine Duke or turbine Baron? | Montblack | Piloting | 1 | December 13th 05 04:54 PM |
Turbine Duke or turbine Baron? | [email protected] | Piloting | 26 | December 13th 05 07:50 AM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Reliability of O-300 | Captain Wubba | Owning | 13 | March 9th 04 12:17 AM |
