I was much more lucky in my ASW-27 at 70% CG when I had a windshear induced
stall while moving to flap L at ~300 above threshold. I lost 269' and was fortunate to recover over lower ground before having to dodge a topsoil pile in the neighboring gravel pit. With headwind component = TAS - GS, the flight data shows 3 windshears, each over a 2 second interval, of -17, +23, -28 kt (application of Pythagorean sum of squares of a triangle on the final shear yields 6 kt of apparent headwind giving -34 kt -- TWICE the recorded wind). Recovery action was flaps negative and stick forward. The usual stall practice at 3000 AGL with a 1 kt/second deceleration has little resemblance to a low level windshear stall. More details on: https://www.dropbox.com/sh/lq9osn15b...wuYvScXya?dl=0 I watched one of those early ASW 20 fatal spins. It was from slow straight = and level flight, not thermaling. The wing dropped sharply and the glider e= ntered a conventional, nose-down spin. The recovery began almost immediatel= y (approx. 1/4 turn) but unfortunately there was not sufficient altitude (t= his began at approx. 300 ft AGL) and the pilot was killed when the glider i= mpacted the ground slightly nose down (i.e., the recovery was almost comple= te) but still sinking. Undocumented tail ballast was probably a factor, as = with UH's situation. Pilot incapacitation due to dehydration may also have = been a factor. The final blow, so to speak, was the lack of a headrest in t= his very early '20 and a battery pack behind the head that came loose. The = pilot was an experienced, high-time competition pilot and instructor. All o= f the contributing factors were avoidable. Chip Bearden ASW 24 "JB" U.S.A. |
I'm very glad this worked out.
But I have my doubts about the wisdom of using negative flaps for stall recovery, especially close to the ground. I don't think that this can be said to be a good practice in general and I would recommend heartily against in my own ASW-20B. -Evan Ludeman / T8 On Wednesday, June 3, 2015 at 11:15:05 PM UTC-4, George Haeh wrote: I was much more lucky in my ASW-27 at 70% CG when I had a windshear induced stall while moving to flap L at ~300 above threshold. I lost 269' and was fortunate to recover over lower ground before having to dodge a topsoil pile in the neighboring gravel pit. With headwind component = TAS - GS, the flight data shows 3 windshears, each over a 2 second interval, of -17, +23, -28 kt (application of Pythagorean sum of squares of a triangle on the final shear yields 6 kt of apparent headwind giving -34 kt -- TWICE the recorded wind). Recovery action was flaps negative and stick forward. The usual stall practice at 3000 AGL with a 1 kt/second deceleration has little resemblance to a low level windshear stall. More details on: https://www.dropbox.com/sh/lq9osn15b...wuYvScXya?dl=0 I watched one of those early ASW 20 fatal spins. It was from slow straight = and level flight, not thermaling. The wing dropped sharply and the glider e= ntered a conventional, nose-down spin. The recovery began almost immediatel= y (approx. 1/4 turn) but unfortunately there was not sufficient altitude (t= his began at approx. 300 ft AGL) and the pilot was killed when the glider i= mpacted the ground slightly nose down (i.e., the recovery was almost comple= te) but still sinking. Undocumented tail ballast was probably a factor, as = with UH's situation. Pilot incapacitation due to dehydration may also have = been a factor. The final blow, so to speak, was the lack of a headrest in t= his very early '20 and a battery pack behind the head that came loose. The = pilot was an experienced, high-time competition pilot and instructor. All o= f the contributing factors were avoidable. Chip Bearden ASW 24 "JB" U.S.A. |
Didn't have the time to check exactly where the the flap handle was going.
At 12:00 04 June 2015, Tango Eight wrote: I'm very glad this worked out. But I have my doubts about the wisdom of using negative flaps for stall recovery, especially close to the ground. I don't think that this can be said to be a good practice in general and I would recommend heartily against in my own ASW-20B. -Evan Ludeman / T8 On Wednesday, June 3, 2015 at 11:15:05 PM UTC-4, George Haeh wrote: I was much more lucky in my ASW-27 at 70% CG when I had a windshear induced stall while moving to flap L at ~300 above threshold. I lost 269' and was fortunate to recover over lower ground before having to dodge a topsoil pile in the neighboring gravel pit. With headwind component = TAS - GS, the flight data shows 3 windshears, each over a 2 second interval, of -17, +23, -28 kt (application of Pythagorean sum of squares of a triangle on the final shear yields 6 kt of apparent headwind giving -34 kt -- TWICE the recorded wind). Recovery action was flaps negative and stick forward. The usual stall practice at 3000 AGL with a 1 kt/second deceleration has little resemblance to a low level windshear stall. More details on: https://www.dropbox.com/sh/lq9osn15b...wuYvScXya?dl=0 I watched one of those early ASW 20 fatal spins. It was from slow straight = and level flight, not thermaling. The wing dropped sharply and the glider e= ntered a conventional, nose-down spin. The recovery began almost immediatel= y (approx. 1/4 turn) but unfortunately there was not sufficient altitude (t= his began at approx. 300 ft AGL) and the pilot was killed when the glider i= mpacted the ground slightly nose down (i.e., the recovery was almost comple= te) but still sinking. Undocumented tail ballast was probably a factor, as = with UH's situation. Pilot incapacitation due to dehydration may also have = been a factor. The final blow, so to speak, was the lack of a headrest in t= his very early '20 and a battery pack behind the head that came loose. The = pilot was an experienced, high-time competition pilot and instructor. All o= f the contributing factors were avoidable. Chip Bearden ASW 24 "JB" U.S.A. |
So far, I've been intentionnaly spinning almost all flapped gliders I flew (about two dozends), and putting flaps to full negative *always* helps to end the spin earlier. Especially close to the ground this is very important, as every fractions of a second counts. Many years ago, when I did an unintenional spin for stupid reasons close to the ground, the negative flaps saved my live.
At 12:00 04 June 2015, Tango Eight wrote: I'm very glad this worked out. But I have my doubts about the wisdom of using negative flaps for stall recovery, especially close to the ground. I don't think that this can be said to be a good practice in general and I would recommend heartily against in my own ASW-20B. -Evan Ludeman / T8 |
Spins | [email protected] | Piloting | 213 | January 27th 08 12:37 AM |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
Spins in Libelles 301 & 201 | HL Falbaum | Soaring | 9 | February 10th 04 06:12 PM |
