Oudie users
Old June 4th 15, 04:32 PM posted to rec.aviation.soaring
D M[_2_]
Default Oudie users
At 13:36 04 June 2015, HGXC wrote:
On Saturday, May 30, 2015 at 11:32:30 AM UTC-4, HGXC wrote:
My Oudie is set up to use external GPS from my Cambridge. My
process
befo=
re flight is to turn on the Cambridge so it will lock the satellites
(start=
blinking), then I turn on the Oudie. It always give me a quick
notice
that=
it has lost the GPS signal and then it works fine. My question is
...is
th=
ere anyway I can tell from the GPS status box on screen what
source its
pul=
ling the GPS from?
=20
Dennis
I noticed that even after I turn on my cambridge and let it acquire
sat=
ellites when I turn on my Oudie it doesn't pick up the primary and
goes
tpo=
secondary. I have to go into the menu and change it back to the
primary
an=
d then its fine. Why doesn't it accept the primary right off? It
connects
t=
o the glider battery right off.
Dennis
Dennis are you hitting save after you make a change to the GPS
input. If you dont save the changes it reverts to what you had last
time you turned it on. Goto Menu/change GPS Input/Menu/save/
then turn it off and turn it back on. Doug
Old June 4th 15, 10:30 PM posted to rec.aviation.soaring
HGXC[_3_]
Default Oudie users
My Oudie is set up to use external GPS from my Cambridge. My process before flight is to turn on the Cambridge so it will lock the satellites (start blinking), then I turn on the Oudie. It always give me a quick notice that it has lost the GPS signal and then it works fine. My question is ...is there anyway I can tell from the GPS status box on screen what source its pulling the GPS from?
DenniS
I do want the secondary if the primary fails after say 10 seconds but I also want it to switch back when the primary becomes available.
Can i do that?
Dennis
Old June 5th 15, 03:42 AM posted to rec.aviation.soaring
Bill T
Default Oudie users
Mine switches back and forth with no issues. If the nano is on and has a good GPS signal the Oudie picks up the Nano. If I unplug the nano, it reverts to internal GPS and when I plug the nano back into the "system", it goes back to the nano.
BillT
Old June 5th 15, 04:22 AM posted to rec.aviation.soaring
Default Oudie users
That is exactly how my Oudie 2 functions.
Automatic switching.
Question for Oudie users [email protected] Soaring 9 September 13th 12 02:17 PM
OurPlane Users??? [email protected] Piloting 2 July 8th 06 11:03 PM
Windows Users... john smith Piloting 0 December 31st 05 12:14 AM
hangsim users? Pete Simulators 0 June 28th 04 02:09 PM
FMC Users Guide Richard Bradshaw Products 0 October 3rd 03 10:43 AM
