Jet turbine reliability
Old June 5th 15, 04:28 AM posted to rec.aviation.soaring
howard banks
Default Jet turbine reliability
Plus a decent dinner for the retriever ...
On Monday, June 1, 2015 at 4:31:42 AM UTC-6, Jim Pengelly wrote:
I'm considering ordering a JS1-C TJ with the jet turbine. A potential syndicate partner is concerned about the reliability of jet turbines from a 'will it start' point of view and a repair cost point of view. I imagine electric turbos are going to be more reliable because of the relative simplicity but you can't buy an electric JS1 or 29. Any comments on jet reliability?
Old June 5th 15, 09:30 AM posted to rec.aviation.soaring
"Gobble as well as gulp...with Jet A at +/- $5 a gallon and AeroShell 560 at $15 a quart that works out to north of $100 to fill up the JS-1"
Well......you could certainly calculate a worst case scenario like that. But as 11USG of Diesel / 2-stroke (4%) oil mix is flight manual approved, this may be a more commonly employed option.
(US prices: 10.6USG @ $2.70 + 0.42USG & $20) is $37.
Glider pilots: Tighter than a fish's a....... :P
Old June 5th 15, 11:10 AM posted to rec.aviation.soaring
Craig Lowrie
The HPH Shark takes 28 liters of Jet A1 + 4% Aeroshell 500. That will
give about 55 minutes cruising at 80-90 knots... The technique is not
climb and glide, rather dolphin flying... pulling up in any residual
energy and in notime you have gained quite a lot of height... It works.
Typically The Shark Jet will do 170km on a tank. The FES version will do
about 100km, whilst the Shark MS (Self Launcher) will do over 300km
on a tank...
Craig
560
approved,
Old June 5th 15, 04:18 PM posted to rec.aviation.soaring
Dave Walsh
500. That will
technique is not
residual
height... It works.
version will do
over 300km
on a tank...
Craig
Interesting thread but surely if you are proposing to spend
£100K on a jet self-launch the cost of the fuel is a minor
matter? For some people the range will be the overriding
factor, if you are not in this category starting reliability might
be more important.
Jet and two-stroke technology: probably will start?
FES/Electric technology: almost certainly will start?
Ask this question: when pick up a Hoover do you think: Will
it start? When you pick up a two-stroke strimmer or chain
saw do you think: Will it start?
David W
Old June 6th 15, 08:02 PM posted to rec.aviation.soaring
jfitch
on a tank...
Craig
560
approved,
For reference, an ASH26E uses about 2 liters for a warm up and climb to 2500 ft agl, and will do 680 Km on its 16 liter tank (according to the book - never had a retrieve that long!). To do that you climb to altitude limits then fold the engine and glide, and repeat as needed. Is the climb performance on a jet significantly better so that the climb and glide technique improves retrieve range over a level cruise?
Old June 7th 15, 07:06 AM posted to rec.aviation.soaring
Craig Lowrie
Climb and glide with the Jet is NOT optimal...
The best speed for the Jet engine is probably over 200 knots (!)....
and whilst this is not possible, the faster the better... so after
briefly climbing away from a field, it is better to accelerate to 80-90
knots and then dolphin-fly, varying speed in accordance with any
residual lift (these is always some)... This technique will produce
the best range...
Craig
That will=20
is not=20
residual=20
works. =
=20
version will do=
=20
300km=20
on a tank...
=20
Craig
=20
AeroShell=20
560
JS-1"
like
that.=
=20
manual=20
approved,
this may be a more commonly employed option.=20
(US prices: 10.6USG @ $2.70 + 0.42USG & $20) is $37. =20
climb to
250=
book -
limits
t=
performan=
technique
impr=
Old June 8th 15, 10:44 AM posted to rec.aviation.soaring
Actually my spreadsheet says that climb/glide is the optimal method even with the jet. I was somewhat surprised by this as with piston retractable engined motorgliders it obviously is as the L/D with engine extended is so bad.. Airplane range is a function of a number of things and L/D is a big one (see Breguet range equation). The L/D with the extended jets would seem to be much better but you don't operate it at best L/D for the climb as the jet best rate of climb speed is very much higher than with a piston engine (thrust drop off with speed is much less and power to aircraft = forward speed x thrust). The single engine jet turbos have much lower thrust to weight than a self launcher so use most of the thrust to stay in level flight particularly if you throttle back to be easier on the jet, so climb/glide probably doesn't work so well there.
There is another consideration and that is the specific fuel consumption of the engine. Jets don't do deep throttling well and 70% is about as low as you want to go before the SFC starts to go bad. This is a good reason for two engines on the self launcher. Just shut down and retract one if you need to fly level because of airspace or meteorological considerations.
One benefit of the high climb airspeed is that you aren't waffling around in a high drag configuration near the stall.
Unless you have a very high thrust/weight, 200 knots is way above the best rate of climb speed for a glider.
To make CS22 takeoff performance you a a T/W of about 0.13 to 0.14. So to let you run the engine(s) at say 70% for takeoff and climb the nominal installed T/W needs to be about 0.18 to 0.20 . This gives reasonable takeoff distance with margin over CS22 and an excellent climb rate at around 100 knots for a modern glider.
As my Ventus has the motorglider CM wings I chose to put the fuel in the fuselage rather than in the wings. Operationally easier when operating out of trailer and no mods to the wings. Weights and speeds are all within the Ventus CM envelope.
Whilst a piston self launcher will use less fuel the jet is comparable to aerotow for launch. Not surprising as the efficiency of the jet is 10 to 11% of fuel energy and SO IS A PAWNEE doing an aerotow.
The jet compares very favorably with a car retrieve also and flying back home in your jet is way more fun than a car retrieve.
I'm not the least little bit interested in retrieve only jets. As a friend of mine once said about the turbo concept: 10% of the utility and 90% of the trouble of a self launcher.
Old June 8th 15, 01:08 PM posted to rec.aviation.soaring
Bruce Hoult
I'm glad someone else worked this out. You're pretty clean with a jet, but it's most efficient at as close to Vne as you dare to go, so your L/D is probably only 15 - 20, whereas once you shut the jet off you'll want to fly at a speed where your L/D is 40+ (well, 30+ anyway).
Running a jet to sustain level flight at 60 - 80 knots is silly, unless that's all the thrust it has, but even then a slightly more powerful jet that lets you go faster will use less fuel.
Old June 8th 15, 01:42 PM posted to rec.aviation.soaring
It's rather 10% of the trouble, at least with the many selflaunchers and turbos I know of. A Solo 2350 can run many years with minimal maintenance and no major issues, something that doesn't seem to happen with selflaunchers very often...
Old June 7th 15, 09:25 AM posted to rec.aviation.soaring
J. Nieuwenhuize
Op zaterdag 6 juni 2015 21:02:52 UTC+2 schreef jfitch:
Yes. The higher the thrust/weight ratio is, the more it pays off. Best CLIMB speed for example for a 450 kg ship and a 800N jet is way above 100 kts.
For highter thrust/weight ratio's, fuel efficiency goes up too; a dolphining flight can get similar mileage to a decent car, even with the typical fuel burn of such a jet (70 kg/hr for the 800N AMT).
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 04:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 07:50 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Reliability of O-300 Captain Wubba Owning 13 March 9th 04 12:17 AM
