APRS is a very viable tracking option. It does require you to have at least an Amateur Radio Technician class license. A few hours of on-line study and a fairly simple written exam are all that's required.
You can use anything from a simple transmitter that ties to a GPS to a full hand held that would also allow voice communications. Most of the country is covered by APRS repeaters that would provide coverage on the ground. 1-2,000 AGL and you should be covered in almost all areas. Depending on the model, you can send and receive email and even make calls through a phone patch. Also, the signal is not blocked as easily as satellite. |
On Saturday, June 6, 2015 at 9:10:08 AM UTC-6, wrote:
APRS is a very viable tracking option. It does require you to have at least an Amateur Radio Technician class license. A few hours of on-line study and a fairly simple written exam are all that's required. You can use anything from a simple transmitter that ties to a GPS to a full hand held that would also allow voice communications. Most of the country is covered by APRS repeaters that would provide coverage on the ground. 1-2,000 AGL and you should be covered in almost all areas. Depending on the model, you can send and receive email and even make calls through a phone patch. Also, the signal is not blocked as easily as satellite. APRS - Cheap, reliable, effective. Any data one wishes can be transmitted at any interval one wishes. Data is fed to the internet for anyone to see. |
Thanks for the comments about APRS. It is not something we use out here in NM, but something we probably need to take a look at...
Thanks again, Renny On Saturday, June 6, 2015 at 9:36:25 AM UTC-6, Bill D wrote: On Saturday, June 6, 2015 at 9:10:08 AM UTC-6, wrote: APRS is a very viable tracking option. It does require you to have at least an Amateur Radio Technician class license. A few hours of on-line study and a fairly simple written exam are all that's required. You can use anything from a simple transmitter that ties to a GPS to a full hand held that would also allow voice communications. Most of the country is covered by APRS repeaters that would provide coverage on the ground. 1-2,000 AGL and you should be covered in almost all areas. Depending on the model, you can send and receive email and even make calls through a phone patch. Also, the signal is not blocked as easily as satellite. APRS - Cheap, reliable, effective. Any data one wishes can be transmitted at any interval one wishes. Data is fed to the internet for anyone to see. |
Glider Crash in CA | Tom (2NO) | Soaring | 27 | September 9th 16 04:26 AM |
Glider Crash in Shirley, NY | [email protected] | Soaring | 15 | May 7th 13 09:23 PM |
Littlefield, Tx Glider Crash | LongJourney | Soaring | 2 | May 2nd 13 03:50 AM |
Scottish Glider Crash | Mike the Strike | Soaring | 22 | July 16th 06 11:00 PM |
Glider/Skydiving Crash | dm | Soaring | 0 | September 27th 03 05:13 PM |
