Glider crash at Moriarty
Old June 6th 15, 04:36 PM posted to rec.aviation.soaring
Bill D
Default Glider crash at Moriarty
On Saturday, June 6, 2015 at 9:10:08 AM UTC-6, wrote:
APRS is a very viable tracking option. It does require you to have at least an Amateur Radio Technician class license. A few hours of on-line study and a fairly simple written exam are all that's required.
You can use anything from a simple transmitter that ties to a GPS to a full hand held that would also allow voice communications. Most of the country is covered by APRS repeaters that would provide coverage on the ground. 1-2,000 AGL and you should be covered in almost all areas. Depending on the model, you can send and receive email and even make calls through a phone patch. Also, the signal is not blocked as easily as satellite.
APRS - Cheap, reliable, effective. Any data one wishes can be transmitted at any interval one wishes. Data is fed to the internet for anyone to see.
Old June 6th 15, 05:52 PM posted to rec.aviation.soaring
Renny[_2_]
Thanks for the comments about APRS. It is not something we use out here in NM, but something we probably need to take a look at...
Thanks again,
Renny
Glider Crash in CA Tom (2NO) Soaring 27 September 9th 16 04:26 AM
Glider Crash in Shirley, NY [email protected] Soaring 15 May 7th 13 09:23 PM
Littlefield, Tx Glider Crash LongJourney Soaring 2 May 2nd 13 03:50 AM
Scottish Glider Crash Mike the Strike Soaring 22 July 16th 06 11:00 PM
Glider/Skydiving Crash dm Soaring 0 September 27th 03 05:13 PM
