Glider crash at Moriarty
Old June 6th 15, 05:50 PM posted to rec.aviation.soaring
Renny[_2_]
Default Glider crash at Moriarty
Steve,
Thanks for the excellent comments. I have been thinking about InReach and it sounds like it is definitely the better choice. We all know that it is more expensive and that one must weigh the pros and cons of any technology, but it is "there," readily available, and it is a real option for pilots to consider.
Regarding Joe I've known him for perhaps 20 years as he flew at Moriarty many times. He was a very good man and he is gone now. We cannot help him now, but perhaps we can better help the next pilot who goes down on a flight out of Moriarty....
Thanks again - Renny
On Saturday, June 6, 2015 at 10:39:06 AM UTC-6, Steve Koerner wrote:
When I've looked at other pilot's Spot tracking output, the majority are quite unreliable in the sense that a significant portion of the transmitted track points are not being received by the Globalstar satellite network. I think this largely stems from a failure to appreciate what a 'clear view of the sky' really means. It is not the overhead sky that matters. IT IS THE 360 DEGREE VIEW OF THE HORIZON THAT IS IMPORTANT.
Catching a Globalstar satellite is a statistical matter. There are only so many satellites whizzing around in low earth orbit. The satellite that you need at any given time will almost always be very near to the horizon; having a satellite anywheres near overhead is a very rare occurrence. The significant consideration is that a mounting strategy that gives only a partial view of the horizon, will result in a statistically similar proportion of tracking messages that don't get out. To have a view of the 360 degree horizon, the unit needs to be mounted flat and high.
Common practice these days is to mount Spot on ones parachute. There is a certain logic to doing that. But there is also a serious flaw in that parachute mounting is frequently not giving reliable tracking mode performance. The problem relates to signal lose through the human body and surrounding airplane parts and the difficulty in keeping the unit flat to the horizon.
Consider the searcher's paradox when a downed pilot uses a Spot which is not transmitting reliably. Searchers will sensibly examine ones past Spot unit performance. If they see that it is not uncommon that your Spot unit misses two or more 5 minute transmits in a row, then the search area becomes something like a 15 minute assumption; that would be like a 25 mile search radius which equals 1900 sq miles. You may never be found. Spot owners should consider this trade-off carefully. My own opinion is that it is much better to have reliable tracking operation than it is to have the unit attached to my parachute.
The other significant point to be made is that Spot is obsolete technology now. InReach is much superior. Tracking interval can be easily set down to whatever you'd like (and willing to pay for); available settings include 5 minute, 2 minute, 1 minute and 30 seconds. InReach communication is fundamentally more reliable because it is a two-way protocol. InReach reports altitude with GPS position which in a search situation is likely to be invaluable. InReach provides two-way text messaging so you can (hopefully) communicate with potential rescuers regarding your situation.
Of note is the fact that Globalstar has said that they will offer a two-way Spot unit pretty soon too. Hopefully that will result in pricing competition with DeLorme.
My condolences to Joe's friends and family. All of us feel great pain when a pilot is lost. It's a bit incongruous to discuss finer points of technology in the face of such a lose. Yet we do need to sort out the problems when we loose one of our own.
Old June 6th 15, 05:52 PM posted to rec.aviation.soaring
Renny[_2_]
Thanks for the comments about APRS. It is not something we use out here in NM, but something we probably need to take a look at...
Thanks again,
Renny
On Saturday, June 6, 2015 at 9:36:25 AM UTC-6, Bill D wrote:
On Saturday, June 6, 2015 at 9:10:08 AM UTC-6, wrote:
APRS is a very viable tracking option. It does require you to have at least an Amateur Radio Technician class license. A few hours of on-line study and a fairly simple written exam are all that's required.
You can use anything from a simple transmitter that ties to a GPS to a full hand held that would also allow voice communications. Most of the country is covered by APRS repeaters that would provide coverage on the ground. 1-2,000 AGL and you should be covered in almost all areas. Depending on the model, you can send and receive email and even make calls through a phone patch. Also, the signal is not blocked as easily as satellite.
APRS - Cheap, reliable, effective. Any data one wishes can be transmitted at any interval one wishes. Data is fed to the internet for anyone to see.
Old June 6th 15, 07:30 PM posted to rec.aviation.soaring
Took a fast look and there are 35 APRS digipeaters in NM. Think of them as cell towers with a very long range. They are networked together and connected to the Internet.
I'd suggest Googling "Amateur Radio Clubs" in your area. I'm sure you wouldn't have much trouble finding someone to give you a demonstration.
Old June 7th 15, 12:06 AM posted to rec.aviation.soaring
Mike the Strike
The aircraft was found very close to locations indicated by SPOT and FLARM, even though there was only one SPOT fix in the general area. The wreckage was difficult to find because it consists of very small pieces and is on a slope. The initial search also only started in late afternoon a few hours before sunset. We do not know if more location data would have helped.
Mike
Old June 7th 15, 04:40 AM posted to rec.aviation.soaring
Frank Whiteley
Mike
Indeed. Local search efforts did not find the wreckage despite hours over the area. This CAP article will show why. http://www.capvolunteernow.com/news/...n ewsID=20326
A few years ago, local pilots did find the wreckage of Stu Kissel's glider, but had they missed it, a little more than a day later it would have been hidden by winter snows for months.
Condolences to Joe's children and grandchildren.
Frank Whiteley
SSA Director, Region 9
Old June 7th 15, 04:39 PM posted to rec.aviation.soaring
Bob Kuykendall
Now that opens a whole new can of worms. Distributed wreckage as described in that article is strongly indicative of in-flight breakup.
Old June 8th 15, 01:57 AM posted to rec.aviation.soaring
Mike the Strike
I would take the CAP report with a pinch of salt since there was no cellphone data to analyze and the location of the site was identified by FLARM and not by radar.
The disposition of the wreckage has not been confirmed, but photos I have seen appear to show most in one location.
Most of the factual data I have seem to conflict with the CAP report!
Mike
Old June 8th 15, 02:16 AM posted to rec.aviation.soaring
howard banks
To reinforce what Mike the Strike says, the CAP report says that some of the wreckage is "miles" away from the main site. Mmmm. The CAP claims total responsibility for finding anything too. Double mmmm.
Our hope is that the loss of Joe will not be in vain and that some system to use existing electronics to locate downed gliders will be devised. Please let us concentrate on that and not speculate on what happened.
On Friday, June 5, 2015 at 7:53:13 PM UTC-6, Tim Taylor wrote:
Very sad news. Any details on what happened?
By Journal North Staff
UPDATED: Friday, June 5, 2015 at 5:30 pm
PUBLISHED: Friday, June 5, 2015 at 4:30 pm
SANTA FE -- New Mexico State police have identified the deceased pilot of a downed glider aircraft found Thursday afternoon southeast of Santa Fe in the Lamy area as 72-year-old Joseph Shepard of Illinois.
According to police, the glider was reported missing Wednesday, after it left the Moriarty Municipal Airport. Satellite and cell phone data, along with a sighting by a pilot who'd been following the glider, led authorities to the Lamy area.
Starting early Thursday, crews from New Mexico Search and Rescue, the Civil Air Patrol's New Mexico Wing, the Army National Guard and the U.S. Border Patrol made searches on the ground and from the air. At about 3 p.m., wreckage was found and confirmed as the missing glider.
The Federal Aviation Administration will investigate the cause of the crash.
Old June 8th 15, 10:08 PM posted to rec.aviation.soaring
Papa3[_2_]
I recently purchased a Delorme Inreach. I was in a hurry to leave for a contest, so I just signed up for one of the mass-market plans (there are special, aviation plans that offer more frequent fixes). I've been very impressed.
- The device itself has rechargable battery that seems to offer many hours worth of transmitting.
- It's easy to tell that it's working.
- It's worked very reliably on every flight I've made.
- Not only that, it's worked quite reliably tucked into my electronics box in the back of the car on the ride home (have forgotten to shut it off several times).
Looking at some of the log files from Mifflin for example, I'm confident that in the worst case, folks would know within a reasonable area where to start looking. Hopefully my old ELT would be working or better yet I'd be in a position to activate the PLB attached to my parachute, but the Delorme seems to be much more reliable than the Spots that my friends use.
As for Joe, I can't say enough how much I enjoyed meeting him a few years ago. I was the CD at Fairfield and we had a pretty significant ridge task. As is sometimes the case for people new to the ridge country, Joe ended up on the wrong ridge late in the day and landed out... way out. When he got back well after dark, instead of being annoyed or frustrated, he was as happy and excited as could be. He was a very nice man, and I'm greatly saddened by this news.
P3
Old June 8th 15, 11:03 PM posted to rec.aviation.soaring
George Haeh
There are a number of technologies, each
with advantages and weaknesses. ELTs
seem to issue more false alarms than
real ones. In a crash, the G switch or the
antenna connection can fail or the
airframe masks the antenna.
With a PLB, you have to have the ability to
erect the antenna and push 1 or 2
buttons. Hopefully the PLB is in reach
when you need to use it.
Flarm has assisted in a number of cases
to locate missing pilots including the odd
live one.
SeeYou Mobile and XCSoar offer
tracking. Bluetooth to your phone allows
it to send texts with your position as long
as there's a cell tower in view. So far it's
worked in my car, but not yet in my glider.
transmitted=
HORIZON THAT IS IMPORTANT. =20
co=
spec=
impres=
sed. =20
hours=
worth of transmitting.=20
- It's easy to tell that it's working.=20
I've made.=20
box=
sev=
eral times).=20
th=
st=
i=
the Spots that my friends use. =20
a=
task.=
u=
go=
h=
sa=
ddened by this news.=20
P3
Glider Crash in CA Tom (2NO) Soaring 27 September 9th 16 04:26 AM
Glider Crash in Shirley, NY [email protected] Soaring 15 May 7th 13 09:23 PM
Littlefield, Tx Glider Crash LongJourney Soaring 2 May 2nd 13 03:50 AM
Scottish Glider Crash Mike the Strike Soaring 22 July 16th 06 11:00 PM
Glider/Skydiving Crash dm Soaring 0 September 27th 03 05:13 PM
