Oh also... I plan to test this on the the ground first as I've had problems in the past with radio interference from setups like this (specifically with the USB charging). If someone who knows about such things can tell us all how best to avoid that problem, I for one would be grateful.
I'm a diehard Kobo/top hat fan.
If you haven't used an ereader screen in a glider, you are in for a treat. I just replaced my first kobo (left other in rental car ![]() and my new (old stock) kobo has the sunlight issue. It's becoming very light during the flight to almost unreadable. This is especially bad with high temperatures. I did not have this problem with my previous kobo so I think this is a QC issue. I have my kobo wired (soldered) to a colibri II. This is an amazing setup that gives you everything you need from a moving map + IGC approval for badge/comp/record flying. The kobo charges the colibri and the whole unit is charged from a micro USB. I have noticed the radio inference if I hold this unit close to my Dittel radio, doesn't effect it unless I hold it close though so it's a non issue for the most part. |
On Monday, June 29, 2015 at 1:14:37 PM UTC-4, PBA wrote:
I'm a diehard Kobo/top hat fan. If you haven't used an ereader screen in a glider, you are in for a treat.. I just replaced my first kobo (left other in rental car ![]() and my new (old stock) kobo has the sunlight issue. It's becoming very light during the flight to almost unreadable. This is especially bad with high temperatures. I did not have this problem with my previous kobo so I think this is a QC issue. I have my kobo wired (soldered) to a colibri II. This is an amazing setup that gives you everything you need from a moving map + IGC approval for badge/comp/record flying. The kobo charges the colibri and the whole unit is charged from a micro USB. I have noticed the radio inference if I hold this unit close to my Dittel radio, doesn't effect it unless I hold it close though so it's a non issue for the most part. Glad I wasn't the only one with the sunlight issue. I've built a temporary shade out of black cardboard. I'll test this out a few more times before claiming victory, but it seemed to help a lot in the two flights where I used the prototype version (i.e. the top of a box taped to the mount with wing tape). |
![]() Glad I wasn't the only one with the sunlight issue. I've built a temporary shade out of black cardboard. I'll test this out a few more times before claiming victory, but it seemed to help a lot in the two flights where I used the prototype version (i.e. the top of a box taped to the mount with wing tape). Try "white/silver", better to reflect sunlight. If need be, pick which color on which side of the shield........ Hope it does not work out, so I can help out VS in the GC...... LOL........ (jk).... |
Running Top Hat on Kobo mini | Ben S | Soaring | 11 | July 21st 15 04:00 PM |
Color Kobo | Dan Marotta | Soaring | 3 | October 25th 14 11:10 PM |
Any experience with aura/optical migraine? | Don Tuite | Piloting | 1 | July 6th 07 02:38 AM |
Pls refresh, flying clubs at FRG, ISP, HWV, HPN? | Michael Robbins | Piloting | 3 | December 13th 06 07:42 PM |
Pls refresh, flying clubs at FRG, ISP, HWV, HPN? | Michael Robbins | Instrument Flight Rules | 3 | December 13th 06 07:42 PM |
