So true. After flying with Jason at Estrella I had check rides at two different soaring locations before renting and I used Jason's soft release technique. HEAVILY CRITICIZED by both CFIs for the soft release.
I have used it a couple of times during my private tows and have seen the towplane fly straight ahead for a couple miles before realizing that I was no longer on tow. |
A so-called soft release is OK by me if I happen to be looking in the
mirror at the time of release but I will log your release height at the point where I realize you're gone, not where you claim you got off. There was an article in Soaring back in the 80s, I believe, which discussed rope tension during tow. It's not very much for a glass glider (20 lb) and I wouldn't think more than 40 lb. or so for a drag master (2-33). There's no harm in releasing at that tension. Why fly a bunch of maneuvers just to get a little slack before releasing? On 7/3/2015 8:32 AM, wrote: So true. After flying with Jason at Estrella I had check rides at two different soaring locations before renting and I used Jason's soft release technique. HEAVILY CRITICIZED by both CFIs for the soft release. I have used it a couple of times during my private tows and have seen the towplane fly straight ahead for a couple miles before realizing that I was no longer on tow. -- Dan Marotta |
Dan, you're the right guy to put a recording digital fish scale on a tow rope and give us an authoritative answer. --bob
On Friday, July 3, 2015 at 8:01:02 AM UTC-7, Dan Marotta wrote: A so-called soft release is OK by me if I happen to be looking in the mirror at the time of release but I will log your release height at the point where I realize you're gone, not where you claim you got off. There was an article in Soaring back in the 80s, I believe, which discussed rope tension during tow.* It's not very much for a glass glider (20 lb) and I wouldn't think more than 40 lb. or so for a drag master (2-33).* There's no harm in releasing at that tension.* Why fly a bunch of maneuvers just to get a little slack before releasing? On 7/3/2015 8:32 AM, wrote: So true. After flying with Jason at Estrella I had check rides at two different soaring locations before renting and I used Jason's soft release technique. HEAVILY CRITICIZED by both CFIs for the soft release. I have used it a couple of times during my private tows and have seen the towplane fly straight ahead for a couple miles before realizing that I was no longer on tow. -- Dan Marotta |
Having an ASH26E, I'm rarely at the distal end of a tow rope. But as a part time, when needed tuggie at Minden, I've been victim of soft releases. We even once had an instructor who seemed to take delight in getting off with a loose rope to see how long I'd keep climbing away. He'd do the same in wave day rotor, when even a normal tension release can easily go unnoticed for awhile.
I like it when a glider says something like, "Glider AA off at 5800, thanks!" That both tells you he's off, and also confirms altitude so there's no surprises paying the tab. bumper |
On Friday, July 3, 2015 at 6:01:02 PM UTC+3, Dan Marotta wrote:
There was an article in Soaring back in the 80s, I believe, which discussed rope tension during tow.* It's not very much for a glass glider (20 lb) and I wouldn't think more than 40 lb. or so for a drag master (2-33).* There's no harm in releasing at that tension.* On a cross-country tow, yes. Not when climbing at 700 fpm at 70 knots! Then you've got to add 1/10th of the glider weight from the climb to the 1/40th of the glider weight from the drag. i.e. more like 100 lb tension than 20 lb (for a modern single seater with a bit of water) |
PowerFLARM protocol 71? | kirk.stant | Soaring | 1 | May 10th 15 04:46 PM |
Who Knew? (dipping protocol) | CupCaked | Piloting | 0 | April 26th 11 04:59 PM |
Bizjet protocol | JS | Soaring | 5 | September 4th 06 06:29 AM |
A fine ridge day in PA - the Ridge Soaring Irregulars ride again | QT | Soaring | 0 | April 6th 06 04:01 PM |
Looking for Ridge Lift/Turbulence Diagram | DrJack | Soaring | 22 | November 14th 03 08:49 PM |
