Last post-- you raise some good points. It is certainly true that the phugoid may either diverge into increasing highs and lows, or damp out into decreasing highs and lows, depending on the glider and the CG position. I'm a light guy and so my CG is usually well aft, making the dynamics on the lively side. Even if the CG is well forward, I think that some mild forward pressure on the stick at this particular point in the oscillation would help the situation.
Thanks for chiming in. S |
I guess my mindset is that if that if you can apply whatever forward stick pressure is needed to freeze the airspeed, and then slowly ease the airspeed back to trim, that is always better then simply riding along with the oscillation, regardless of whether the oscillation is going to get more severe, or damp out. Obviously the latter situation is much more user-friendly than the former...
S |
So....you are still in the White Room.
What about bank? |
playing pool | maish941 | Military Aviation | 0 | March 19th 12 07:26 AM |
$30,000 pitch links | Stuart Fields | Home Built | 3 | January 16th 06 02:13 AM |
$30,000 pitch links | Stuart Fields | Rotorcraft | 7 | January 15th 06 07:00 PM |
AI pitch bounce | Mike Noel | Owning | 3 | November 29th 04 11:43 PM |
playing mfs2004 | Silent Bob. | Simulators | 3 | October 15th 04 02:02 PM |
