That TLAR doesn't look right
Old July 13th 15, 04:43 AM posted to rec.aviation.soaring
Default That TLAR doesn't look right
On Sunday, July 12, 2015 at 5:31:27 PM UTC-6, SoaringXCellence wrote:
A faster, higher L/D glider needs a lot more distance/time to dissipate energy and being 600' laterally abeam the touch down would create a significant challenge, both with the turns required to intercept final and the 45 degree base base turn reference.
Not really. EASA CS-22 paragraph 22.75 under which most high performance gliders were certificated says:
"It must be shown that the sailplane has a glide
slope not flatter than one in seven at a speed of
1·3 Vso with air brakes extended at maximum weight."
So basically all JAR-22/CS-22 gliders have less than 7:1 L/D with the spoilers open.
I've done several 45 degree angle of depression approaches with an early model DUO and it worked out fine.
BRS chutes. Why doesn't everyone use them? 5Z Soaring 0 January 22nd 11 01:34 AM
It doesn't fly, BUT... Bart[_2_] Home Built 8 June 20th 07 10:52 PM
TLAR help Slick Soaring 8 May 20th 06 12:56 AM
FAA doesn't know FBOs. Kyler Laird General Aviation 3 February 5th 04 04:06 PM
Doesn't GOOGLE...? Michael Horowitz Home Built 5 December 17th 03 05:11 PM
