A huge reduction in solar output is predicted to occur by then.
Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) If things do get worse, then hopefully by 2030 we'll have got better at scratching around in weak conditions, so we'll be sorted. |
On Mon, 13 Jul 2015 14:09:42 -0700, David Hirst wrote:
A huge reduction in solar output is predicted to occur by then. Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) There may well be a connection: the Maunder Minimum, when there were very few sunspots from 1645 to about 1715, coincided with the middle part of the Little Ice Age (1350 to about 1850), during which Europe and North America experienced very cold winters. However, as AFAIK there was no good understanding of either IR or UV radiation during the Maunder Minimum nor any reliable means of measuring the amount of solar energy reaching the Earth, any association between the two events is at best supposition, but should it happen again we are now well enough instrumented to discover what, if any, mechanism connects the two. If things do get worse, then hopefully by 2030 we'll have got better at scratching around in weak conditions, so we'll be sorted. Could be a problem if reduced solar energy stabilises the atmosphere. But that seems unlikely, simply because I've never seen any reports of a large drop in the population of raptors and other land-based soaring birds during the Maunder Minimum. If soaring had gotten difficult then, I'd have expected it to have affected birds that find food by soaring. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
If anyone wants to dump a new condition Arcus I'll give you $10K for it....you deliver of course!!
On Tuesday, July 14, 2015 at 9:50:38 AM UTC+12, Martin Gregorie wrote:
On Mon, 13 Jul 2015 14:09:42 -0700, David Hirst wrote: A huge reduction in solar output is predicted to occur by then. Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) There may well be a connection: the Maunder Minimum, when there were very few sunspots from 1645 to about 1715, coincided with the middle part of the Little Ice Age (1350 to about 1850), during which Europe and North America experienced very cold winters. However, as AFAIK there was no good understanding of either IR or UV radiation during the Maunder Minimum nor any reliable means of measuring the amount of solar energy reaching the Earth, any association between the two events is at best supposition, but should it happen again we are now well enough instrumented to discover what, if any, mechanism connects the two. The theorized mechanism is fewer sunspots - less solar wind - more cosmic rays reaching earth - more nucleation of aerosols - more clouds - higher reflectivity - more energy radiation into space - lower temperatures. The key link in this chain (more cosmic rays - more nucleation of aerosols) has been experimentally verified at CERN. http://en.wikipedia.org/wiki/Henrik_...imat e_change IPCC reports state that cloud reflectivity and proportion of cloud cover is one of the most important and yet least understood aspects of the global climate system. |
OMG... Not... global... COOLING! snic, snic
On 7/16/2015 10:38 PM, Bruce Hoult wrote: On Tuesday, July 14, 2015 at 9:50:38 AM UTC+12, Martin Gregorie wrote: On Mon, 13 Jul 2015 14:09:42 -0700, David Hirst wrote: A huge reduction in solar output is predicted to occur by then. Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) There may well be a connection: the Maunder Minimum, when there were very few sunspots from 1645 to about 1715, coincided with the middle part of the Little Ice Age (1350 to about 1850), during which Europe and North America experienced very cold winters. However, as AFAIK there was no good understanding of either IR or UV radiation during the Maunder Minimum nor any reliable means of measuring the amount of solar energy reaching the Earth, any association between the two events is at best supposition, but should it happen again we are now well enough instrumented to discover what, if any, mechanism connects the two. The theorized mechanism is fewer sunspots - less solar wind - more cosmic rays reaching earth - more nucleation of aerosols - more clouds - higher reflectivity - more energy radiation into space - lower temperatures. The key link in this chain (more cosmic rays - more nucleation of aerosols) has been experimentally verified at CERN. http://en.wikipedia.org/wiki/Henrik_...imat e_change IPCC reports state that cloud reflectivity and proportion of cloud cover is one of the most important and yet least understood aspects of the global climate system. -- Dan Marotta |
On Saturday, July 18, 2015 at 2:57:05 AM UTC+12, Dan Marotta wrote:
OMG...* Not...* global...* COOLING!* snic, snic* I think the temperature goes up and down quite a large amount (10+ C) due to a variety of natural causes, and yet stays in a bounded range without diverging to a desert world or an ice world. Somehow mammals have survived 200 million years and many cycles of this. Even great apes have survived 40 million years of it, without any technology. I guess one school is that we're just plain lucky that things haven't exceeded that range, and a small extra push could send us over, to a 2nd Mars or Venus. Frankly, I don't believe it. I think there must be some natural negative feedback "thermostat" that we don't understand yet. |
Bruce Hoult wrote on 7/16/2015 9:38 PM:
On Tuesday, July 14, 2015 at 9:50:38 AM UTC+12, Martin Gregorie wrote: On Mon, 13 Jul 2015 14:09:42 -0700, David Hirst wrote: A huge reduction in solar output is predicted to occur by then. Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) There may well be a connection: the Maunder Minimum, when there were very few sunspots from 1645 to about 1715, coincided with the middle part of the Little Ice Age (1350 to about 1850), during which Europe and North America experienced very cold winters. However, as AFAIK there was no good understanding of either IR or UV radiation during the Maunder Minimum nor any reliable means of measuring the amount of solar energy reaching the Earth, any association between the two events is at best supposition, but should it happen again we are now well enough instrumented to discover what, if any, mechanism connects the two. The theorized mechanism is fewer sunspots - less solar wind - more cosmic rays reaching earth - more nucleation of aerosols - more clouds - higher reflectivity - more energy radiation into space - lower temperatures. The key link in this chain (more cosmic rays - more nucleation of aerosols) has been experimentally verified at CERN. http://en.wikipedia.org/wiki/Henrik_...imat e_change IPCC reports state that cloud reflectivity and proportion of cloud cover is one of the most important and yet least understood aspects of the global climate system. "While the link between cosmic rays and cloud cover is yet to be confirmed, more importantly, there has been no correlation between cosmic rays and global temperatures over the last 30 years of global warming. In fact, in recent years when cosmic rays should have been having their largest cooling effect on record, temperatures have been at their highest on record." http://www.skepticalscience.com/cosm...termediate.htm -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
In 1804 the population of the earth was 1 billion people. It took 123
years to add another billion, then 33 years, then 14, then 12 to get the population up to 6 billion by 1999 (source https://www.learner.org/courses/envsci/unit/text.php?unit=5&secNum=4). Now the human population is roughty 10.8 billion people (source http://populationpyramid.net/world/2015/)! I don't suppose all those people blowing CO2 into the atmosphere has anything to do with this? On 7/19/2015 10:08 PM, Eric Greenwell wrote: Bruce Hoult wrote on 7/16/2015 9:38 PM: On Tuesday, July 14, 2015 at 9:50:38 AM UTC+12, Martin Gregorie wrote: On Mon, 13 Jul 2015 14:09:42 -0700, David Hirst wrote: A huge reduction in solar output is predicted to occur by then. Thankfully, they mean sunspot activity, not heat output, though the lack of sunspots will likely cause some noticeable weather changes. (http://www.space.com/19280-solar-act...h-climate.html) There may well be a connection: the Maunder Minimum, when there were very few sunspots from 1645 to about 1715, coincided with the middle part of the Little Ice Age (1350 to about 1850), during which Europe and North America experienced very cold winters. However, as AFAIK there was no good understanding of either IR or UV radiation during the Maunder Minimum nor any reliable means of measuring the amount of solar energy reaching the Earth, any association between the two events is at best supposition, but should it happen again we are now well enough instrumented to discover what, if any, mechanism connects the two. The theorized mechanism is fewer sunspots - less solar wind - more cosmic rays reaching earth - more nucleation of aerosols - more clouds - higher reflectivity - more energy radiation into space - lower temperatures. The key link in this chain (more cosmic rays - more nucleation of aerosols) has been experimentally verified at CERN. http://en.wikipedia.org/wiki/Henrik_...imat e_change IPCC reports state that cloud reflectivity and proportion of cloud cover is one of the most important and yet least understood aspects of the global climate system. "While the link between cosmic rays and cloud cover is yet to be confirmed, more importantly, there has been no correlation between cosmic rays and global temperatures over the last 30 years of global warming. In fact, in recent years when cosmic rays should have been having their largest cooling effect on record, temperatures have been at their highest on record." http://www.skepticalscience.com/cosm...termediate.htm -- Dan Marotta |
On Monday, July 20, 2015 at 12:59:45 PM UTC-4, Dan Marotta wrote:
In 1804 the population of the earth was 1 billion people.* It took 123 years to add another billion, then 33 years, then 14, then 12 to get the population up to 6 billion by 1999 (source).* Now the human population is roughty 10.8 billion people (source)! I don't suppose all those people blowing CO2 into the atmosphere has anything to do with this? Dan Marotta That's a good question! The CO2 that people exhale is the product of metabolism; the food that they eat is combined with Oxygen to produce water, CO2, and energy. So, it's Carbon that was in the system to start with. |
The earth is a closed system except for meteors, asteroids, etc. We are
all made of natural resources, we consume them, and we excrete them. I say more Ferraris and fewer people! On 7/20/2015 1:09 PM, wrote: On Monday, July 20, 2015 at 12:59:45 PM UTC-4, Dan Marotta wrote: In 1804 the population of the earth was 1 billion people. It took 123 years to add another billion, then 33 years, then 14, then 12 to get the population up to 6 billion by 1999 (source). Now the human population is roughty 10.8 billion people (source)! I don't suppose all those people blowing CO2 into the atmosphere has anything to do with this? Dan Marotta That's a good question! The CO2 that people exhale is the product of metabolism; the food that they eat is combined with Oxygen to produce water, CO2, and energy. So, it's Carbon that was in the system to start with. -- Dan Marotta |
SELL: PNA HP 310 /314 | TRKA | Soaring | 0 | October 17th 10 09:21 PM |
By 2030, commercial passengers will routinely fly in pilotlessplanes. | Bob Fry | General Aviation | 101 | April 28th 10 10:43 PM |
By 2030, commercial passengers will routinely fly in pilotlessplanes. | Bob Fry | Piloting | 103 | October 10th 05 01:33 AM |
Buy and Sell GSE | knowmad | Piloting | 0 | September 29th 05 07:46 PM |
Chadwick to sell | clescure | Rotorcraft | 2 | June 19th 04 03:08 AM |
