Hello,
	Not a Pilot, but always interested in the engineering aspects. This question came up, and I realize that I am not sure of a correct answer. Regarding the compass heading that shows in the glass displays: How is it derived ? GPS ? If not GPS, what ? Is it then Magnetic or True ? Does the Pilot have to correct for variation/declination changes during a flight ? Does aviation use True or Magnetic when discussing or flying ? etc. ? Thanks, Bob  |
			 Hello Bob, I'm unable to provide the answer as to the technology employed by computer-generated displays to display magnetic information, but I would expect something like a Hall device might be employed. As you implied, it could as easily be derived from GPS data corrected for magnetic variation at the particular location. Magnetic/compass headings are not true, but magnetic. Navigation Sectional charts http://skyvector.com/ are depicted in True coordinates, and the pilot/navigator must correct for magnetic variation in drafting his flight plan. ATC expects all course/heading numbers to be magnetic. You'll find more information he http://www.faa.gov/regulations_policies/handbooks_manuals/, and he http://www.faa.gov/regulations_policies/handbooks_manuals/aviation/pilot_handbook/media/PHAK%20-%20Chapter%2015.pdf. Hope that helps. Best regards, Larry Dighera On Mon, 13 Jul 2015 18:36:54 -0400, Bob wrote: Hello, Not a Pilot, but always interested in the engineering aspects. This question came up, and I realize that I am not sure of a correct answer. Regarding the compass heading that shows in the glass displays: How is it derived ? GPS ? If not GPS, what ? Is it then Magnetic or True ? Does the Pilot have to correct for variation/declination changes during a flight ? Does aviation use True or Magnetic when discussing or flying ? etc. ? Thanks, Bob  |
Hi,
	Thanks for replies and help. What I was referring to are the new, modern, "glass" displays where most everything shown is derived from transducers located elsewhere. e.g. when a display shows a Heading of, e.g., 075, it is of course getting this info. from some kind of transducer, located elsewhere. Is it derived directly from GPS ? A Hall effect compass ? or,... ? Thanks again; interesting subject. Bob ------------------------------------------------------------------------------------------------------------- On 7/13/2015 6:36 PM, Bob wrote: Hello, Not a Pilot, but always interested in the engineering aspects. This question came up, and I realize that I am not sure of a correct answer. Regarding the compass heading that shows in the glass displays: How is it derived ? GPS ? If not GPS, what ? Is it then Magnetic or True ? Does the Pilot have to correct for variation/declination changes during a flight ? Does aviation use True or Magnetic when discussing or flying ? etc. ? Thanks, Bob  |
	, Dave Doe says... In article , lid, Bob says... Hi, Thanks for replies and help. What I was referring to are the new, modern, "glass" displays where most everything shown is derived from transducers located elsewhere. e.g. when a display shows a Heading of, e.g., 075, it is of course getting this info. from some kind of transducer, located elsewhere. Is it derived directly from GPS ? A Hall effect compass ? or,... ? Thanks again; interesting subject. Well I'm not sure on that - perhaps others will reply. However, cellphones usually use one or more magnetometers (hope I spelt that right   ).  A GPS can't get a magnetic heading, only True.I play with Arduino's a bit - and Googling 'arduino magentometer' gives a few results, eg... http://bildr.org/2011/01/hmc6352/ http://bildr.org/2012/02/hmc5883l_arduino/ http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino I *assume* that the compass in a glass display uses the same sort of technology. Apologies to the apostrophe police - that's terrible! -- Duncan.  |
Dave Doe  wrote:
	In article , , Dave Doe says... In article , lid, Bob says... Hi, Thanks for replies and help. What I was referring to are the new, modern, "glass" displays where most everything shown is derived from transducers located elsewhere. e.g. when a display shows a Heading of, e.g., 075, it is of course getting this info. from some kind of transducer, located elsewhere. Is it derived directly from GPS ? A Hall effect compass ? or,... ? Thanks again; interesting subject. Well I'm not sure on that - perhaps others will reply. However, cellphones usually use one or more magnetometers (hope I spelt that right   ).  A GPS can't get a magnetic heading, only True.I play with Arduino's a bit - and Googling 'arduino magentometer' gives a few results, eg... http://bildr.org/2011/01/hmc6352/ http://bildr.org/2012/02/hmc5883l_arduino/ http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino I *assume* that the compass in a glass display uses the same sort of technology. Apologies to the apostrophe police - that's terrible! -- Duncan. The display in a glass panel is GPS course. You need a magnetic compass to know your heading. The difference between the two is wind correction, magnetic variation and compass deviation. While I don't doubt that someone could create a device that would send magnetic heading info to a glass panel, it would have to be some obvious secondary display. You want to be looking at your true course if you want to get from A to B. -- Don Poitras  |
In article , , Don
	Poitras says... Dave Doe wrote: In article , , Dave Doe says... In article , lid, Bob says... Hi, Thanks for replies and help. What I was referring to are the new, modern, "glass" displays where most everything shown is derived from transducers located elsewhere. e.g. when a display shows a Heading of, e.g., 075, it is of course getting this info. from some kind of transducer, located elsewhere. Is it derived directly from GPS ? A Hall effect compass ? or,... ? Thanks again; interesting subject. Well I'm not sure on that - perhaps others will reply. However, cellphones usually use one or more magnetometers (hope I spelt that right   ).  A GPS can't get a magnetic heading, only True.I play with Arduino's a bit - and Googling 'arduino magentometer' gives a few results, eg... http://bildr.org/2011/01/hmc6352/ http://bildr.org/2012/02/hmc5883l_arduino/ http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino I *assume* that the compass in a glass display uses the same sort of technology. Apologies to the apostrophe police - that's terrible! -- Duncan. The display in a glass panel is GPS course. You need a magnetic compass to know your heading. The difference between the two is wind correction, magnetic variation and compass deviation. While I don't doubt that someone could create a device that would send magnetic heading info to a glass panel, it would have to be some obvious secondary display. You want to be looking at your true course if you want to get from A to B. The OP is asking about just about such a device. And it's clear they do exist in a glass display (a compass that is). Take for example, the Cessna website. If you navigate to say the Cessna TTx - and check out the glass Avionics section, and look at Equipment Details (rather than Standard Features), it specifies a Magnetometer ... "GMU-44 Magnetometer (dual)" Albiet a compass is almost obsolete and uncessary with todays navigation equipment, but let's not forget runways - still lined up and named magnetic. Makes me wonder when that will change. -- Duncan.  |
Dave Doe  wrote:
	In article , , Don Poitras says... Dave Doe wrote: In article , , Dave Doe says... In article , lid, Bob says... Hi, Thanks for replies and help. What I was referring to are the new, modern, "glass" displays where most everything shown is derived from transducers located elsewhere. e.g. when a display shows a Heading of, e.g., 075, it is of course getting this info. from some kind of transducer, located elsewhere. Is it derived directly from GPS ? A Hall effect compass ? or,... ? Thanks again; interesting subject. Well I'm not sure on that - perhaps others will reply. However, cellphones usually use one or more magnetometers (hope I spelt that right   ).  A GPS can't get a magnetic heading, only True.I play with Arduino's a bit - and Googling 'arduino magentometer' gives a few results, eg... http://bildr.org/2011/01/hmc6352/ http://bildr.org/2012/02/hmc5883l_arduino/ http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino I *assume* that the compass in a glass display uses the same sort of technology. Apologies to the apostrophe police - that's terrible! -- Duncan. The display in a glass panel is GPS course. You need a magnetic compass to know your heading. The difference between the two is wind correction, magnetic variation and compass deviation. While I don't doubt that someone could create a device that would send magnetic heading info to a glass panel, it would have to be some obvious secondary display. You want to be looking at your true course if you want to get from A to B. The OP is asking about just about such a device. And it's clear they do exist in a glass display (a compass that is). Take for example, the Cessna website. If you navigate to say the Cessna TTx - and check out the glass Avionics section, and look at Equipment Details (rather than Standard Features), it specifies a Magnetometer ... "GMU-44 Magnetometer (dual)" Albiet a compass is almost obsolete and uncessary with todays navigation equipment, but let's not forget runways - still lined up and named magnetic. Makes me wonder when that will change. -- Duncan. You're right. I was wrong. It makes sense that the glass HSI would need to work like the mechanical one and that gets set manually to the current compass setting. -- Don Poitras  |
Bob  wrote:
	Regarding the compass heading that shows in the glass displays: The heading information from the PFD comes from a directional gyro. The directional gyro's drift is constantly corrected (slaved) by a magnetic compass located in the tailcone on the airplane. The output of this compass is electrically "enhanced" and amplified through a "flux gate". Bottom line: A very accurate, stable, compass reading that never needs adjustment. -- Dallas  |
| Thread Tools | |
| Display Modes | |
| WTB: PZL KI-13 Compass | Romeo Delta | Soaring | 1 | October 30th 17 08:47 AM |
| Still have a compass? | [email protected] | Soaring | 19 | November 22nd 13 11:33 PM |
| compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 08:39 AM |
| Looking for a PZL compass | Kirk Stant | Soaring | 8 | February 12th 04 10:27 PM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
