water ballast
Old July 14th 15, 04:40 PM posted to rec.aviation.soaring
Tango Eight
Default water ballast
On Tuesday, July 14, 2015 at 1:37:39 AM UTC-4, Bob Kuykendall wrote:
On Monday, July 13, 2015 at 8:19:25 PM UTC-7, Jim Lewis wrote:
If Reynolds Number is the ratio of inertial forces to viscous forces where does aircraft weight come in?
What was the inertia part again?
Inertia of the *fluid*.
Re hasn't anything to do with the mass of the glider.
Evan Ludeman / T8
Old July 14th 15, 04:56 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Evan Ludeman / T8
Yep. Rho Vee Elle over Mu. Fluid Density times velocity times chord divided by viscosity. But as the glider gets heavier, it flies faster at the same lift coefficient, so Vee gets bigger.
And, Jim. I am not seeing the "Performance Enhancement Through Airfoil Shape Correction" series in the Johnson Flight Tests section of the SSA Website. Might have to search an issue at a time from about 1977 through 1981. Dick got his Ventus in 1981, so the PIK went away then.
Steve
Old July 14th 15, 05:23 PM posted to rec.aviation.soaring
Jim Lewis[_2_]
Thank you Steve. I'll dig into the archive.
Water Ballast Tripod [email protected] Soaring 3 July 31st 12 05:43 PM
DG-300 Water Ballast Bags noel.wade Soaring 7 February 18th 10 02:39 AM
Winter Water Ballast Scott Alexander[_2_] Soaring 14 November 27th 09 03:11 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
