An AHRS (Altitude Heading Reference System) must use at minimum three sensors: Accelerometers, Gyros, and Magnetometers (or GPS).
Algorithms that use just the accelerometers to correct for the gyro bias will diverge (get a VERY wrong answer) over time if you are in a coordinated turn. (The filters in question try to observe the long term trend of which way is "down." Circling in a thermal will fool these fairly quickly.) The magnetometer or GPS input must be used to observe the turn and prevent incorrect estimation of the gravity vector. A fairly well-known university (with which I am not affiliated) discovered this about a decade back when they were commanding their fixed-wing UAVs to loiter by circling. After a couple minutes they would overbank, enter a spiral dive, and crash rather dramatically... |
Artificial Horizon – HELP! | Mike Mike Ground | Soaring | 8 | September 30th 11 08:17 AM |
SNEFA Artificial Horizon | nimbus | Soaring | 2 | December 21st 08 09:00 AM |
Electronic Artificial Horizon | Stuart Kinnear | Soaring | 14 | May 3rd 07 06:56 PM |
artificial horizon | DavidH | Home Built | 14 | March 14th 07 07:47 AM |
Artificial horizon pinout? | [email protected] | Home Built | 3 | July 16th 06 02:02 PM |
