Wing wheel needed...
Old July 17th 15, 04:37 PM posted to rec.aviation.soaring
Default Wing wheel needed...
On Thursday, July 16, 2015 at 12:16:43 PM UTC-6, wrote:
Looking for a wing wheel. I have an ASW-19.
If anyone has one they want to sell please call or email me. I'm in WA and will cover shipping.
Thanks,
Nick
two zero six 954 33 three three
I am assuming you mean a wheel for tow out and ground handling purposes.
Considerations:
Pick one that can slip over the wing and clamp rather than one that has to slide on from the tip. This is especially important if you have winglets.
Pick one that can be broken down and stow in the trailer with the rest of the tow out gear.
It should not be overly heavy but also not too light either. You want some weight to keep the wing from lifting in the wind. I see pilots using their parachutes as extra weight on the wing for this. Not a good idea. If the chute were to deploy in wind it would wreak havoc.
I have a M&M Fabrication wheel by Mark Mocho. It works well. He can build one specifically for your ship.
Old July 17th 15, 08:21 PM posted to rec.aviation.soaring
That's a good point. The ASW-19 has a double tapered wingtip --
neither the leading nor trailing edge are perpendicular to the
direction of travel. I built my own wing wheel, but M&M are
really good about working to match your plane.
Matt
Youth soaring program looking for wing wheel for large-chord wing Jay[_2_] Soaring 1 September 17th 14 02:44 AM
ASW-20A Left Wing or Inboard Wing Skin Needed Coucked Soaring 0 August 29th 10 02:43 PM
Ingredients for a wing wheel needed [email protected] Soaring 1 May 16th 09 06:11 PM
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
