NTSB F-16 & Cessna 150 midair preliminary report
Old July 19th 15, 04:33 PM posted to rec.aviation.soaring
Dan Marotta
Default NTSB F-16 & Cessna 150 midair preliminary report
I was a bit stunned by the apparent lackadaisical behavior on the part
of both the F-16 pilot and the controller. Advice to turn should be
acted on immediately in a conflict situation. From the writeup it
seemed that neither the pilot nor the controller showed any concern
about such a close encounter. Of course that could simply be that the
printed word can't convey stress or tone in a voice.
Also notable is the fact that, had the F-16 pilot /_not_/ turned when he
did or /_had_/ turned when instructed, the collision would likely not
have occurred.
Vaughn, I agree with you on the PCAS altitude. My last conflict was
noted as -300 ft and, when I spotted the aircraft, it was about 100 ft
above my altitude.
On 7/19/2015 8:52 AM, Vaughn wrote:
On 7/18/2015 8:40 PM, son_of_flubber wrote:
http://www.ntsb.gov/_layouts/ntsb.av...15FA259A&rpt=p
To me, this is the crucial passage:
"At 1100:49, the radar target of the F-16 was located 1/2 nautical
mile northeast of the Cessna, at an indicated altitude of 1,500 feet,
and was on an approximate track of 215 degrees. At that time, the
Cessna reported an indicated altitude of 1,400 feet, and was
established on an approximate track of 110 degrees. At 1100:52 the
controller advised the F-16 pilot, "traffic passing below you 1,400
feet." "
I find transponder-reported altitudes to be pretty notoriously
inaccurate in general. So it seems to me that these two planes
indicating only 100 feet apart (but only reporting their altitudes in
100 feet increments) should have been considered at the SAME altitude.
With my PCAS, I consider +/- 400 to be the same altitude.
Dan Marotta
Old July 19th 15, 05:52 PM posted to rec.aviation.soaring
kirk.stant
feet, and was on an approximate track of 215 degrees. At that
time, the Cessna reported an indicated altitude of 1,400 feet, and
was established on an approximate track of 110 degrees. At 1100:52
the controller advised the F-16 pilot, "traffic passing below you
1,400 feet." "
So, the Cessna was pretty close to the beam, and therefore may not have shown up on the F-16s radar.
It almost sounds like both the controller and the Viper driver expected the other to take the appropriate action - neither took full responsibility for preventing the possible collision, expecting the other to do it!
So much for a transponder ALONE being the solution to midairs...
And until installing ADS-B Out in a certified airplane is a LOT cheaper, what are the chances that that Cessna owner would have bothered?
Would ADS-B in have provided timely warning to the Cessna of the approach of the F-16? As I understand it, since neither the Cessna or the F-16 had ADS-B out, the Cessna would not have received any traffic info from the ADS-B ground stations.
Thanks, FAA, for this idiotic implementation - withholding traffic data as an incentive to equip with ADS-B out!
Dual band ADS-B receivers SHOULD receive both weather AND all traffic! That would probably guarantee that just about everything flying would at least get traffic info!
Kirk
66
Old July 19th 15, 06:43 PM posted to rec.aviation.soaring
Ramy[_2_]
A note about transponder altitude inaccuracy. I also noticed significant inaccuracy when I used the Zaon MRX but once I switched to PowerFlarm I found mode C reported altitudes much more accurate, so I suspect the significant inaccuracy that Dan noted is due to MRX error, not necessarily transponder error.
Ramy
Old July 19th 15, 07:11 PM posted to rec.aviation.soaring
Darryl Ramm
Ramy
You may get larger MRX errors if the glider does not have a local
transponder (that is being interrogated and seen by the MRX)...if it does
the MRX will use the transponder's transmitted altitude instead of it's
internal pressure sensor--which can be affected by cockpit ventilation.
With the number of issues that I believe Ramy had with his MRX maybe it was
not properly identifying the local transponder.
Old July 20th 15, 04:39 PM posted to rec.aviation.soaring
Controller appears to have given an abundance of information to the F-16 pilot. The F-16 pilot, in one of the most highly maneuverable aircraft ever made, did virtually nothing with it to provide margin. huh.
Old July 20th 15, 08:45 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
And if you have two planes, one heading 110 degrees, one heading 260 degrees, the plane heading 110 degrees is reported to be at the 12 o'clock position of the plane heading 260 degrees, why would you tell the plane heading 260 degrees to "Turn left to heading 180 degrees"? This seems to me to be continuing to aim the 260 degree heading plane at the 110 degree heading plane.
It seems like it would have made more sense to turn the F-16 to the right.
And, it could also be read that there would have been no conflict at all had the F-16 pilot not begun a left turn. By my read, he had changed his heading approximately 45 degrees in the direction directed by the controller when the collision occurred. So, if the F-16 pilot had done nothing, there would not have been a collision? Is this how good our ATC radar is? Or was there a controller error that helped facilitate the collision?
Too much Monday Morning Quarterbacking.
Old July 21st 15, 01:33 AM posted to rec.aviation.soaring
hey I'm not the one suggesting the controller should have said go right instead of left. But I'll admit its a fair point.
Bottom line, that first call: traffic, 12 o'clock 2 miles opposite direction - ..close in altitude, is good info and more than a lot of us get when we end up finding ourselves close to another aircraft. It's a shame that was not enough to prevent the accident.
Old July 20th 15, 05:11 PM posted to rec.aviation.soaring
Dan Marotta
That could be the case, however... The MRX PCAS uses an internal
barometric sensor in the absence of an own ship's transponder. I've
observed its startup and noted that it initially reports a transponder
code of 3707 or some other nonsense, after my transponder is turned on
and begun replying to interrogations, the PCAS with show a TX code of
1200 and, finally, 1202 to which my Trig is set to reply.
I don't know what the required Mode C/S accuracy is below FL180, but if
it's +/- 200 feet, then you could occasionally see a 400' error. That or
my PCAS lost lock with my Trig, or it's just sloppy. Next time I see an
aircraft on which I've received an alert, I'll check the PCAS for the
transponder code it's using for its calculations. If I gain some
insight, I'll report it here.
Ramy
Dan Marotta
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
Preliminary NTSB Report on the Oshkosh P51 Crash Released Dudley Henriques[_2_] Piloting 58 August 6th 07 06:58 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
NTSB Preliminary report on HPN crash Peter R. Instrument Flight Rules 83 May 10th 05 08:37 PM
ntsb report Peter Clark Instrument Flight Rules 38 April 1st 05 03:18 AM
