PowerFLARM choking on too many targets?
Old July 21st 15, 02:02 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default PowerFLARM choking on too many targets?
Um, so why didn't you title your post:
"FlarmView choking on too many targets?"
I fly with 10-14 PowerFLARM-equipped gliders. Our club standardized on Butterfly displays early on, one or two private owners have FLARMview. We haven't seen this behaviour.
When I had a similar problem with my Butterfly about a year ago, it manifested only with specific unit settings (imperial units - kts, nm, ft), oriented vertically. You might try changing from whatever units you use to the other (metric), and change orientation, to help troubleshoot the problem. The more the data, the easier the fix. I also took a cellphone video of the problem, posted it to youtube, and sent the link in. It took Butterfly folks about a day to fix and produce a beta version for me.
The Butterfly is not as bright as flarmview, but the support is very good, and they're (the equipment, the factory support folks, and the Canadian dealer) easy to work with.
I'm curious how many of the gliders had transponders as well as PowerFLARMs - it seems to me that might double the I/O the processor has to deal with. Only one local glider has a transponder here...
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
TCAS and slow moving/stationary targets? Papa3 Soaring 8 April 6th 11 01:18 AM
JSOW-C1 IR Seeker Tracks Moving Targets At Sea [email protected] Naval Aviation 0 May 29th 08 06:57 AM
USAF strike al-Qaida targets in Somalia for Israel -- NOT! Mike Weeks Naval Aviation 0 January 9th 07 05:46 AM
B-58's targets in a nuclear war KDR Naval Aviation 29 December 12th 06 03:24 AM
