NTSB F-16 & Cessna 150 midair preliminary report
Old July 21st 15, 05:08 PM posted to rec.aviation.soaring
Ramy[_2_]
Default NTSB F-16 & Cessna 150 midair preliminary report
Even in a glider, if you are too close to maneuver left or right, a quick pull up, or a dive, is the fastest way to prevent a midair.
Ramy
Old July 21st 15, 05:35 PM posted to rec.aviation.soaring
Dan Marotta
Yup... Only a week ago, I did a quick unload and bottom rudder to avoid
a conflict in a thermal.
Ramy
Dan Marotta
Old July 22nd 15, 12:04 AM posted to rec.aviation.soaring
On Tuesday, July 21, 2015 at 12:35:47 PM UTC-4, Dan Marotta wrote:
Yup...* Only a week ago, I did a quick unload and bottom rudder to
avoid a conflict in a thermal.
Dan Marotta
Not saying right or wrong in your case (wasn't there, didn't see it....), but, "for others", keep in mind there "may" be a glider just under your belly!!
While you may have missed one "issue", you may have created another "issue"......
Stated from a comp pilot/CFIG...... just think before acting.... I know time is short at times, but try.
Please?
Old July 22nd 15, 03:46 PM posted to rec.aviation.soaring
Dan Marotta
A very good point but, in this case, I was aware of my surroundings.
The G-103 was the only glider other than my own in the immediate area.
He had a better thermal than I did, so I moved over to join from below.
He increased his turn rate just as I was entering, putting us on
possibly conflicting paths. To dodge him I could have: rolled out
slightly and gone under him to the outside of his turn, but that would
have been too close and he would not have seen me; increased my bank
angle and pulled inside his turn, but that would expose my belly and I
would have lost sight of him and, quite frankly, would have been rude;
put the nose down and seek lift elsewhere. Doing the last maneuver I
never lost sight of him until I was speeding away. That sounds like a
lot to consider in a short time but maintaining situational awareness
makes this less of an issue than it might sound like.
Dan Marotta
Please?
Dan Marotta
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
Preliminary NTSB Report on the Oshkosh P51 Crash Released Dudley Henriques[_2_] Piloting 58 August 6th 07 06:58 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
NTSB Preliminary report on HPN crash Peter R. Instrument Flight Rules 83 May 10th 05 08:37 PM
ntsb report Peter Clark Instrument Flight Rules 38 April 1st 05 03:18 AM
