NTSB F-16 & Cessna 150 midair preliminary report
Old July 22nd 15, 06:03 PM posted to rec.aviation.soaring
Bob Pasker
Default NTSB F-16 & Cessna 150 midair preliminary report
regarding altitude differences, 91.217 requires that the altimeter report pressure altitude correctly within 125 feet. So two aircraft, one reporting FL050 but 125ft high at 5,125 MSL and another reporting FL053, but 125ft low at 5,175 MSL will pass very close to each other, especially if one of them might be an ASH-30 in a level turn.
https://www.law.cornell.edu/cfr/text/14/91.217
Old July 22nd 15, 06:46 PM posted to rec.aviation.soaring
Vaughn
FL050 but 125ft
MSL will pass
in a level turn.
I believe the typical situation is much worse than that. 91.217 only
seems to require that the equipment meet that standard on the day it was
calibrated, and then 95% probability of meeting that standard is
accepted. After that, the equipment goes out to meet the real world
and all bets are off until the next calibration!
Also, remember that a transponder only reports altitude in 100 foot
increments, so 5,125 MSL might report the same as 5,199 MSL.
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
Preliminary NTSB Report on the Oshkosh P51 Crash Released Dudley Henriques[_2_] Piloting 58 August 6th 07 06:58 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
NTSB Preliminary report on HPN crash Peter R. Instrument Flight Rules 83 May 10th 05 08:37 PM
ntsb report Peter Clark Instrument Flight Rules 38 April 1st 05 03:18 AM
