Condor and Windows 10
Old August 1st 15, 05:15 PM posted to rec.aviation.soaring
Default Condor and Windows 10
Thanks, you got me on the right track. The original Glidertools cable apparently uses a PL2303HXA version of the chip which will not be supported in Win 8/8.1/10. There is a later version of the chip, PL2303HXD, that is supported by Win 10 drivers which can be found he http://www.prolific.com.tw/US/ShowPr...id=225&pcid=41. Sounds like it's time to build a new cable.
Old August 3rd 15, 02:14 PM posted to rec.aviation.soaring
Paul Remde
Hi,
The Condor-Oudie cable I sell that is made by Goddard in the USA works great
in Windows 8.1 and should work great with Windows 10. I'll test it soon.
http://www.cumulus-soaring.com/godda...ndor-Oudie-1p5
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old August 7th 15, 05:43 AM posted to rec.aviation.soaring
Don't waste your time buying a cable for condor.
You can build it for under $10 and there are only 3 wires to connect. The driver is the most difficult part to find and IF you build your own you will know where the driver can be found and use a generic driver.
Old August 8th 15, 02:13 AM posted to rec.aviation.soaring
Personally, I just don't understand the rush to install Win10.
From a security mailing list I subscribe to:
--Windows 10 Security and Privacy Issues (August 3 & 5, 2015) Windows 10 collects a significant amount of data from users. The privacy policy is described in the operating system's privacy statement, but users often agree to Terms of Service Agreements without actually reading the text. These articles describe some of the ways user data is gathered and used, and provide recommendations for changing settings to protect privacy.
http://www.wired.com/2015/08/windows...ngs-need-know/
http://www.slate.com/articles/techno...em.single.html
[Editor's Note (Pescatore): Since Microsoft has joined the "updates are free, we will get revenue from selling information about users"
bandwagon with Google, Facebook, etc., Windows 10 does try to sneak a lot of info leakage into the default settings. Enterprise pressure on Microsoft is needed to get these changed to opt-ins before enterprise migration.]
Old August 8th 15, 06:17 PM posted to rec.aviation.soaring
Dan Marotta
I had Windows 10 installed for about 3 days and backed it out. During
that process I learned that you have 30 days to decide not to use it.
Since reverting to 8.1, I get popups at every start up telling me about
"upgrading" to the free Windows 10... BTW, the rollback built into the
upgrade did not put my laptop back to its previous configuration.
Things work differently now... My advice is don't do it just yet.
Dan Marotta
Old August 9th 15, 06:38 AM posted to rec.aviation.soaring
Windows upgrades are not usually optional, unfortunately, for very long anyway. Hardware manufactures only make drivers that work with old OS's for so long and Microsoft won't release new security patches after a certain point for an old os.
Old August 24th 15, 09:09 PM posted to rec.aviation.soaring
Agreed, and here is a successful outcome. I bought this cable: http://www.adafruit.com/products/954 for $9.95 and hooked it up in just a few minutes.
It's based on a Prolific PL2303 TA chip that has a tested Win10 driver. The driver install package even has a subordinate program to see which chip is in your device. There are other USB to serial chips out there, FTDI for example, but make sure you have an authentic FTDI chip since there has been a flood of imitation ones will not work. Another important issue is that if you connecting a Vertica/Avier/Gliderguider to the computer, be sure that your USB to Serial converter is a low voltage TTL (LVTTL, 3.3 v) chip and not just Serial or just 5v TTL. The regular serial or TTL voltages can harm the flight computer. Most commercial USB to Serial cables are not made for this use nor can they be easily converted, and even the specialty cables used with Arduino and Raspberry Pi micro computers sometimes come with a configurable 3.3 vs. 5 volt option, so be sure to get the voltages right.
So, after several hours of testing, I'm happy to report that Condor under Win10 has no problems, and the new cable/driver combo works as well as the old.
The Dogs Of War - Condor-dog.jpg (1/1) Mitchell Holman[_7_] Aviation Photos 1 January 5th 14 03:10 PM
Condor sim questions 2NO Soaring 3 March 21st 13 01:28 PM
Condor Evan Ludeman[_4_] Soaring 29 March 13th 13 01:16 AM
Condor Thanksgiving and Condor Christmas Contests [email protected] Soaring 0 October 22nd 12 03:33 PM
Must Condor run as Administrator under Windows XP? Roger Worden Soaring 4 June 24th 08 03:29 AM
