Airspeed indicator ?
Old August 2nd 15, 01:17 AM posted to rec.aviation.soaring
Default Airspeed indicator ?
My airspeed indicator seems to have devolved a leak and pitot pressure is causing readings on the old uncompensated winter vario. When I blow on the pitot tube and disconnect the static line of the airspeed indictor you can hear air moving through the static line from the airspeed indicator.
Has anyone head of this before?
I'm guessing replacing the airspeed indicator is the solution.
Feedback would be great.
Nick
Old August 2nd 15, 02:09 AM posted to rec.aviation.soaring
John Cochrane[_3_]
Yes. I had an ASI fail. Very prompt service from Winter.
John Cochrane
Old August 2nd 15, 02:45 AM posted to rec.aviation.soaring
The diaphragm has failed, likely due to corrosion.
No owner fix applicable.
UH
Old August 2nd 15, 03:36 AM posted to rec.aviation.soaring
Papa3[_2_]
Just sent my Fahrtmesser back to Winter. Very quick turnaround and reasonably painless. The instructions are on their Website. That's assuming of course you have a Winter ASI (which is in like 90% of the glass fleet).
P3
Old August 2nd 15, 05:43 AM posted to rec.aviation.soaring
How fast was the turn around from winter?
Old August 2nd 15, 07:05 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Does your glider perhaps have an old fashioned capsule total energy
compensation system on the mechanical vario? A leak in the diaphragm in
that would account for the symptoms you describe.
is
can
Has anyone head of this before?=20
I'm guessing replacing the airspeed indicator is the solution.=20
Feedback would be great.=20
Nick
Old August 2nd 15, 07:25 AM posted to rec.aviation.soaring
bumper[_4_]
UH
Not legal of course, but a friend of a friend once repaired one, figured not much to lose, took it apart, bellows had a crack- cleaned, a little solder on the split. Worked fine.
Old August 2nd 15, 02:32 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
What glider are we talking about? I have an old (1revolution) ASI, with faded speed restrictions for LS 3a. I have checked it against my master ASI and it is working properly............How about $100 bucks?
JJ
Looking for a used 57 mm airspeed indicator Scott Alexander[_2_] Soaring 0 October 13th 12 07:28 PM
Airspeed Indicator Strangeness Frank[_1_] Soaring 6 June 9th 08 01:24 PM
verifying airspeed indicator Heino & Deanne Weisberg Home Built 11 October 22nd 05 07:36 PM
Need glider airspeed indicator [email protected] Soaring 1 June 21st 05 09:57 PM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
